Is there a way to hook up a cassette potty directly to sewer at site?
Discussion in 'Port-A-Potties / Cassette Toilets / Bath Houses' started by yarzy, Jun 8, 2015.
  1. yarzy
    yarzy Member
    88
    Jan 25, 2013
    As the topic says, I would LOVE to be able to hook up the cassette holding tank directly to the sewer at a campground. Is there a way to do this? I would assume some cutting would be involved, etc, but I am not sure what else. Maybe some sort of pump? Any info would be great.
    Thanks!
  2. Customer
    Customer Well-Known Member
    2,436
    243
    Jun 5, 2014
    no
  3. DigitalGuru
    DigitalGuru Active Member
    525
    29
    Jul 5, 2011
    Michigan
    I would say anything is possible, but this would be a major retrofit. Since the discharge for the cassette is on top of tank, you've have to cut an opening in the bottom of the cassette tank, and cut a hole in the floor of the camper to pass the pipe through to the sewer line. If you were to go this route, I would remove the cassette tank if possible and just go straight to the sewer line. I'm not sure if the cassette flush will still function without the tank below it. I know it has some "guides" that inhibit opening the blade without the tank below it.
    And keep in mind you would only be able to hook up to sewer after this conversion, no using the cassette without an attached sewer. I guess you could buy a second tank and have one modded for sewer and one standard. But with all the modding if anything goes wrong or leaks, you've got quite a mess on your hands and your campsite.
    Good luck, let us know if you attempt it!
    DG
  4. E3 Junkie
    E3 Junkie Greetings from Granada Hills, CA.
    314
    Sep 22, 2012
    No, and what's worse, is there is the issue of cleaning out whatever pipe you use to accomplish this feat. There shouldn't be any issue with you emptying the cassette directly into a sanitary sewer in a space with full hook ups. It might stink for a few minutes, but that's about the extent of it.
  5. jerbear
    jerbear Active Member
    238
    50
    Jun 11, 2015
    Indiana
    the hose that you would use for a travel trailer or motor home will not work with a porta potty . Just dump it and have rinse water handy .
  6. NorcrossFlyer
    NorcrossFlyer Active Member
    296
    29
    Oct 26, 2015
    North Georgia
    You can probably connect a hose from the cassette to the sewer opening. The problem with that is that it would probably overflow your potty right around the same time the waste starts working its way down the hose.
