It fixed it self????
Discussion in 'Lift Systems' started by PopupG, Sep 1, 2011.
  1. PopupG
    PopupG New Member
    169
    Sep 12, 2009
    Ok I have started a couple threads about how my lift system was very hard to lower (04 Fleetwood Sedona) got a couple tips to lube the lift arms, lube the wiffletree, ect... I did none of these things cause I have been too busy but today I lowered the roof and it was a smooth as silk, I mean it lowered so nice it took no effort at all! What the heck happened?
  2. 1madscot
    1madscot Member
    256
    Nov 6, 2010
    It could be something as simple as a burr somewhere on the gears, or temperature differences allowing the parts to mesh better. Then again, maybe the pop-up fairy fixed it for you... [:D] I'd still get under there and lube those parts though.
  3. Yellowkayak
    2,198
    Mar 13, 2007
    X2
    JJ
  4. Dusty82
    Dusty82 Active Member
    3,513
    Jun 23, 2008
    Northern Nevada
    X3
    Gremlins aren't usually known for fixing stuff. I get nervous when things like that happen to me. [:D]
    On a serious note, it's possible something was stuck in a place that was obstructing something else, and you might have cleared it out of the way temporarily by working the lift system up and down. Better to go ahead and check it all out to be sure.
  5. dgeddes
    dgeddes Member
    181
    Nov 13, 2010
    I speak from experience here....a problem with the roof going up or down that seems to just go away is a harbinger of things to come.
  6. riverwalker
    riverwalker New Member
    295
    Jul 25, 2010
    1st time i forgot to raise my stabs I noticed just how nice and smooth/easy the roof lowered. Manual says to raise when lowering or raising, the difference in ease makes me wonder if someone who wrote the manual was having a off day.
  7. Hacksaw
    Hacksaw Active Member
    1,875
    Aug 23, 2009
    With the lift system on the Coleman/Fleetwood I would venture a guess that you had a stuck cable. Inspect them as close as you can and hope that there is no damage.If there is replace it.It isn't worth the risk.
