Jayco 1206- 2008 advice
Discussion in 'Camper Pre-Purchase Questions' started by anothersmith, Sep 10, 2019.
  1. anothersmith
    anothersmith Member
    72
    Aug 24, 2018
    i’ve found a good looking 2008 Jayco 1206. Looks to be in good overall condition but has a tiny hole in the roof.
    How concerned about the hole should I be? Easy repair?
    Above are some pics of the trailer and the hole. Asking $5,900.
    Thoughts?
  2. BikeNFish
    BikeNFish Well-Known Member
    3,008
    1,916
    Apr 24, 2017
    Maplewood, MN
    Price seems high unless it is in pristine condition. NADA has the high retail at $4,550. What area are you in? That has a lot to do with price.
  3. Ladiesman
    Ladiesman Active Member
    238
    120
    Feb 6, 2018
    A little epoxy will seal that right up.
  4. anothersmith
    anothersmith Member
    72
    Aug 24, 2018
    I am in the SF Bay Area so unfortunately everything g is more expensive here. If I can get it down to about $5k I’ll be happy
  5. anothersmith
    anothersmith Member
    72
    Aug 24, 2018
    I was thinking some SunCure might work. I use it on Surfboards and it starts curing under UV light.
  6. wmgeorge
    wmgeorge Member
    81
    21
    Sep 6, 2019
    The big question, why is a perfect hole in the roof? Has it leaked water to the plywood underneath and started to rot?
    Also no A/C and for me that would be a no sale.
    The box in the front, has it had leaks? The one we looked had a leak in the past and had been fixed to a point. Part of that floor extends into the camper and it was soft.
  7. jmkay1
    4,947
    1,836
    I agree check the hole very carefully. Jayco used plywood in their roof at one time, if it got wet rot could easily have set in. So feel around that hole very carefully, shine a light in it. If everything feels solid around it and looks like it didn’t breach the membrane of the roof by a lot, then just seal it. On my old 1990 Jayco I had an awning accident (it flipped over my roof poles and all) that left almost an exact same type of hole, except thank goodness it didn’t access to the wood inside.
  8. wmgeorge
    wmgeorge Member
    81
    21
    Sep 6, 2019
    That hole was not punched by a pole it looks like it was drilled. I would cut a small piece of aluminum that size and get either the official roof sealant or white silicone sealer and fill between the roof aluminum and plywood under completely and out the top and set your patch on that and seal around and under it. Weigh down with something.
    If its rotted underneath it would be a no go for me.
  9. anothersmith
    anothersmith Member
    72
    Aug 24, 2018
    My guess is that something pointy was dropped/put on the roof. In the 5th photo you can see the tarp on the lawn that is used to cover the pup when stored, hoping this has been used for a while.
    No AC is not a problem as we will camp on the coast in the hottest part of summer, moving inland during spring and autumn.
    Hopefully i'll get out there early next week to see it in person........
  10. Ladiesman
    238
    120
    Feb 6, 2018
    That roof is chemlite the same as in refrigerated semi trailers. They make a patch kit that even comes with sheet to rub on it to give the texture. Easy fix
    anothersmith likes this.
  11. anothersmith
    anothersmith Member
    72
    Aug 24, 2018
    Good to know. We aren’t due any rain here in CA for a bit so I have some time. That said, if I pull the trigger I’ll be patching it up as soon as I can.
  12. anothersmith
    anothersmith Member
    72
    Aug 24, 2018
    She’s mine! Got it for $5,200 which I feel is fair in the SF Bay Area.
    The hole in the roof is tiny and looks more like a chip in person, should be an easy fix.
    Fired up to get her out on Saturday with the kids for a first run!
    jmkay1 likes this.
  13. BikeNFish
    3,008
    1,916
    Apr 24, 2017
    Maplewood, MN
    Congratulations!
  14. Freckles2stars
    Freckles2stars New Member
    Sep 21, 2019
    I saw a video on You tube for a Forest River PUP they said the hole in the ceiling was a marking point for an air conditioner. It is to find the studs on both sides and to cut the hole for the placement of an air conditioner. Maybe this is what your hole is?
  15. Grandpa Don
    Grandpa Don Active Member
    380
    152
    Sep 5, 2018
    Well, how did the first trip go? Where did you go?
  16. Dingit
    Dingit Well-Known Member
    900
    424
    Mar 8, 2017
    I don't think that's a perfect hole. I think that's a perfect penny next to the actual hole to show that it is small and irregular. :)
