Jayco Door Issue
Discussion in 'Miscellaneous Repairs & Maintenance' started by Hammer_2012, Jun 17, 2014.
  1. Hammer_2012
    Hammer_2012 New Member
    55
    Jul 12, 2012
    Hey everyone,
    I have a 2007 Jayco 1206, and the door frame doesn't stay in place very well when it's installed. The door itself works fine, but the frame keeps coming out of place on one side. There are two white plastic "turn latches" on each side of the frame, but on the one side the latches don't come close to holding the door frame in place. I've attached a few photos below.
    Anyone else have this issue or come up with a fix? Any help would be greatly appreciated!
    Cheers
  2. gerryrobinson
    gerryrobinson New Member
    28
    Mar 20, 2014
    Does it get worse (more gap) when someone is on the bunk end closest to this side of the door? If so, this might be a case where the wall framework is detatching from the flooring next to the door. This seems to be a common issue. Check out this thread: http://www.popupportal.com/index.php?topic=51453.0
  3. WeRJuliIan
    906
    91
    May 15, 2014
    Sarasota, FL
    I've noticed a similar issue, if I'm careless with levelling, especially fore-to-aft (see my post about not believing cheap levels... :) )
    Could that be your problem?
  4. MNTCamper
    MNTCamper Well-Known Member
    1,227
    421
    Jun 14, 2014
    MN
    Make sure that your piano hinge is firmly attached along the whole length of the door and check any other screws and attachments to make sure they are where they should be. Proper camper height and leveling are also issues that need to be looked at.
  5. COdreaming
    COdreaming New Member
    344
    Mar 26, 2013
    Mine does the same thing (2009 Jayco 1206). I've recently discovered that if I move the roof towards to door, the gap closes up. I either have a weird roof lean, or something else going on. I'm going to try tinkering with it to see what I can do. I've also thought about taking those turn knobs off and replacing them with the turn style locks you see on windows, that way it pulls the gap closed.
  6. ccptbo
    ccptbo Well-Known Member
    2,763
    157
    Jun 8, 2013
    Peterborough area, ON
    This was our issue a couple times as well, last year. We've gotten very good with levelling and never had an issue since.
  7. Hammer_2012
    55
    Jul 12, 2012
    That was with the trailer levelled (even double checking the level with 2 different levels). The system seems a little under designed but I'll try playing around with the roof to see if that helps.
    Cheers
  8. Jayko
    Jayko Jayco 141J aka Big Bertha
    1,263
    18
    Jul 10, 2012
    Try cranking on your stabilizers a bit harder to see if you can close the gap?
    I know, I know, stabilizers are just that, for stabilization.
    If you can close the gap with the stabilizers on the gap side of the box...it seems your wall may be detaching from the floor.
