Jayco Lift System Repair
Discussion in 'Lift Systems' started by JaycoEagle, May 3, 2015.
  1. bobinfleet
    bobinfleet Active Member
    463
    189
    Sep 2, 2011
    Hampshire UK
    Could be the cable pulleys or the roof posts or springs need lubing
  2. jmkay1
    4,957
    1,838
    . A cable may have jumped off the pully causing too much tention. Could also be something as simple as a pully not rotating any more. I would suggest to locate the pullies and start from there.
  3. VALPAL
    VALPAL New Member
    Apr 1, 2019
    Does anyone have a diagram on how the cables run? My eye hook opened up which in turn set my cable flying and alot of Slack buy the post I see pulleys and just need to know how the cable goes around the pulleys.
  4. MNTCamper
    MNTCamper Active Member
    916
    208
    Jun 14, 2014
    MN
    Search the forums for Jayco lift system. There are posts with links to a diagram of the entire system.
  5. Finally Off The Ground
    Finally Off The Ground New Member
    19
    Sep 6, 2018
    You were right about that. Three pulley's not turning. I've replaced those and two cables. Wondering about how you know how far from the winch to place the main cable block (?) when attaching the eye-bolts. Any ideas on that? Thanks for your suggestions.
  6. jmkay1
    4,957
    1,838
    . I'm afraid I don't know the answer to that. Perhaps this document could help. https://www.google.com/url?sa=t&sou...FjACegQIBRAB&usg=AOvVaw1564XJXUuumvfLiQ4SUBsa
  7. MNTCamper
    916
    208
    Jun 14, 2014
    MN
    When the camp is fully up, there should be about one foot of main cable before the winch. My recommendation is to look at the diagram and fix process, support all for corners at the same correct height, then attach the eye bolts and tighten until about the same tension on each. Lower and raise the top and check for every height and adjust as necessary.
  8. Finally Off The Ground
    19
    Sep 6, 2018
  9. Finally Off The Ground
    19
    Sep 6, 2018
    Thanks MNTCamper.
  10. Sneezer
    1,550
    545
  11. Finally Off The Ground
    19
    Sep 6, 2018
