JayCo Popup Rebuild (Pictures)
Discussion in 'Camper Restoration Projects' started by DFire2, Jun 20, 2016.
  1. DFire2
    DFire2 Active Member
    260
    54
    Jun 18, 2016
    Central Michigan
    So my wife and I were given a bit beat-up JayCo Eagle popup camper. We don't know what the year, title just says JayCo popup camper.
    PS. At the time of this posting, we are currently already down to the studs and flooring removed, so pictures may be out of date order...
    This is what we want to do...
    + New cushion covers
    + New valances
    + New vinyl floor
    + New paneling
    + New 120VAC and 12VDC wiring and circuits
    + Remove propane lines (won't need them)
    + Remove water system (will just run off 6gal tank under sink)
    + Clean and repair, possibly if needed, replace the canvas
    + Change out ceiling lights
    + Add solar
    + Add new jacks (old ones are rusted very badly)
    + Bend bumper back to normal (looks like someone backed into tree)
    + Replace/repair roof lift system (currently RAD pneumatic lift system)
    + Remove exteriors stickers and decals
    + Repaint exterior and add decals
    + Remove and rebuild cabinets
    + Reroute wiring inside of walls through studs
    + Reseal exterior corners
    ...and many more.
    Here are some photos before demolition...
    Let's get started!
    Cabinets go bye bye! (didn't take many pictures of this part as I was removing exterior decals while wife was removing cabinets)
    Paneling go bye bye! Wheel wells are a pain!
    Time to tear up the flooring, then to sanding the leftover panel glue from the studs.
    It's getting a bit more roomy in here...
    Drilled new wiring holes...5/8"
    Remove exterior decals...
    Plug up some of the holes from removed propane and water...
    We had to spray some KILZ on the aluminum backing because it had started to mold and mildew, mostly due to the rotted corner pictured. Replaced the corner and resealed it.
    The original layout, or at least very close...
    The new layout...just flipped around
    My color-coded layout diagram...
    Also to note, I went to school for CADD (computer drafting) so decided to make a simple visual of the cabinet layout...
    (a bare bones layout drawing)
    (added cabinet walls)
    ...and we're still going...
    AlexVanEks, PopUpSteve and rcc like this.
  2. Dubbya
    6,130
    53
    Aug 2, 2011
    Steinbach, MB
    Loving this! Been there, done that myself so I think I'll stick around and offer some encouragement as I follow your progress. [8D]
    Go ahead and click on the camera under my username to see the links to my resto and mod threads. I'm sure you'll find a few helpful ideas there. If you have any questions, just ask! I'm happy to help in any way I can. [:D]
  3. DFire2
    260
    54
    Jun 18, 2016
    Central Michigan
    I modified the OP to show a few images a forgot. Thanks for the encouragement!
  4. Katskamper
    Katskamper Active Member
    750
    203
    Nov 21, 2015
    Fort Worth, TX
    you are ambitious!
  5. edh
    edh Active Member
    1,073
    Jun 2, 2008
    Thanks for posting, looking forward to more pics as the work continues.
  6. DFire2
    260
    54
    Jun 18, 2016
    Central Michigan
    Somehow when I measured for flooring, originally I measured 6'x12' exactly. Then got it cut and somehow now it's 6'9"x12' instead. Grrr, guess I'll try and conceal that 9" worth of exposed plywood under a cabinet.
    Sent from my LG-VS980 using Tapatalk
  7. RFryer
    RFryer Hopkinton, MA
    762
    Mar 10, 2009
    Hopkinton, MA
    I feel your pain on that one! [:(!]
  8. Dubbya
    6,130
    53
    Aug 2, 2011
    Steinbach, MB
    well, if they cut it at the store, take your receipt and the material back and get another piece.
  9. DFire2
    260
    54
    Jun 18, 2016
    Central Michigan
    Was thinking that, but it's only 9". Should be able to cover it with cabinets. Besides, I'd have to match the pattern, too.
    Update! Wife and I started to remove one half of the lift system so we can get the flooring in.
    Put 2x4's in next to the lift system so we can loosen it.
    We broke every bolt holding the lift system to the floor...10 bolts for the one side.
  10. Dubbya
    6,130
    53
    Aug 2, 2011
    Steinbach, MB
    Yep, that'll happen. [;)]
  11. Rhconcepts
    Rhconcepts Active Member
    604
    88
    Oct 1, 2015
    Blaine MN
    Well it looks like you got a great project to work on, I don't see any wood rot :) keep the pictures coming.
  12. HackFamily
    HackFamily Member
    44
    Jun 20, 2016
    This is amazing! You are doing a fantastic job at taking great pictures.
  13. DFire2
    260
    54
    Jun 18, 2016
    Central Michigan
    Bought some CLR and a variety pack of wire wheels, gonna try and shine up the lift tracks a bit, then paint them to look good.
  14. Dubbya
    6,130
    53
    Aug 2, 2011
    Steinbach, MB
    You don't need to use CLR on them.
    Just use the wire wheels and some sandpaper if required, wipe them down with Varsol to remove any grease or contaminants and spray on some Rustoleum. [8D]
  15. DFire2
    260
    54
    Jun 18, 2016
    Central Michigan
    So wife and I got a lot done today...
    Grinding the rust off the tracks, at least mostly
    ...then painted them, loved this color of brown.
    Wife took off the top vent and painted the parts...
    Came out real nice...and she also cleaned the ceiling :)
    I finally got some time to work on the back of the popup, getting the plywood cut for the tail light support, still have to make one to put above it for the others.
    Next up, finishing the back end, then hopefully the flooring sometime soon, then electrical, and paneling, and then some...
    AlexVanEks likes this.
  16. DFire2
    260
    54
    Jun 18, 2016
    Central Michigan
    Ok, so today DW and I got the rest of the lift system removed, including the crank and winch, only broke half the bolts this time :)
    DW put the lights and fixtures back up after cleaning the ceiling, with help from her "taller half" ;)
    I finished my work on the back end of the PUP, now there is good support for all SEVEN lights and also the spare tire bracket (which will probably get bolted on tomorrow)
    Oh! This is the colors we are going to paint...
  17. The KSassie
    The KSassie New Member
    Jun 20, 2016
    Can't believe all the progress we've made so far! Can't wait to get the flooring in soon!!! Thanks for being my "taller half"! <3
  18. Don_D
    Don_D I'd rather be camping!
    37
    Jul 11, 2014
    Awesome progress, you picked an ambitious project but I love seeing how these turn out and the customization's along the way. It has much less water damage than I would have expected. Thanks for posting all the pics!
  19. DFire2
    260
    54
    Jun 18, 2016
    Central Michigan
    Yeah, the water damage was actually quite minimal. Only lightly in the corners where the caulk seals had become weak. I still have to reseal some of those.
    We found the exact paint coat at Home Depot, $30/gal. Will need about 3-4 4x8 panels to do the walls. That's after I get the electrical run and flooring down. I might have to move the electrical outlet in the wall though...
  20. chrisxs5
    chrisxs5 Test
    197
    May 30, 2014
    Just following, keep up the good work.
