Jayco porch light...repair or replace
Discussion in 'Lighting, Interior and Exterior' started by Kampus, Jun 3, 2019.
  1. Kampus
    Kampus Active Member
    182
    168
    Jun 16, 2017
    Slate Belt, Pa
    Got a 2000 Jayco Eagle 10UD with a fairly common porch light.
    http://tweetys.com/star-porch-light-w-switch-and-amber-lensaspxaspx.aspx
    The switch is in bad shape. Feels like there is sand in it...probably just rust as it doesn't appear to be an outdoor rated switch either. Gotta fight with it to keep it on. I was going to replace just the switch, but cant see a way to get into it.
    Anyone replace the switch or entire light that can offer some insight in how it is mounted or how to get into it to service the switch?
    Thanks in advance.
  2. nineoaks2004
    7,533
    3,249
    Dukes, Fl
    The one that came on my TT was white (attracted bugs), I went to camping world and found a light with a yellow lens (less bugs) it was on sale but had no switch, I ordered a toggle switch from All Electronics.com for $1.00 and installed it. Been working great for 3 years now. If you remove the light you may be able to replace the switch from the rear.
  3. eoleson1
    eoleson1 Well-Known Member
    2,318
    733
    Jul 5, 2011
    Macomb County Michigan
    I replaced the porch light on my Starcraft. I lost the lens, and couldn't find a replacement. The swap out was really easy. The RV store gave me a new piece of weather stripping along with the light. It was held in with four wood screws. It took maybe 10 minutes start to finish, including cleaning the surface for the new weatherstrip.
    Kampus likes this.
  4. crackerJack
    crackerJack Well-Known Member
    1,155
    324
    Jan 6, 2014
    Scottsville, KY
    I swapped the whole assembly.
    New switch, bulb, and lens. It was pretty simple.
    Kampus likes this.
  5. roybraddy
    roybraddy Well-Known Member
    2,286
    824
    Mar 23, 2016
    King George, Virginia
    I was going to change my light out for one of those Star Lights SL1000 Motion Sensor LED RV Porch Light - White or Black.
    These have the motion sensor built-in... Comes on when you walk up to your trailer if activated...
    Google image
    On my POPUP the outside light is pretty low close to the ground. If I did this I would want to relocate the light up on the roof side where it would be up higher and still be under the awning when you are setup at the camp site...
    Roy Ken
  6. Kampus
    182
    168
    Jun 16, 2017
    Slate Belt, Pa
    Thanks for all the feedback. I ended up ordering a whole new one off of amazon. Looks to be the same model. Hoping the screw holes line up.
  7. Kampus
    182
    168
    Jun 16, 2017
    Slate Belt, Pa
    Well that was stupid easy.
    kcsa75 and Sjm9911 like this.
  8. Sjm9911
    5,235
    2,841
    An old guy once told me to stope talking about doing the job and just do it, lol. Glad it was easy!
    Kampus likes this.
  9. lucky13don
    lucky13don Active Member
    207
    26
    Jul 13, 2016
    sf bay area
    Alright,another jayco eagle.. I took canned air and blew the switch out. Works good. Also check the wiring for crud.
