Jayco suspension
Discussion in 'Road Safety Systems' started by Family Travels, Mar 3, 2020.
  1. Family Travels
    Family Travels New Member
    25
    Oct 26, 2019
    Illinois
    I purchased a used popup in October and it's warm enough that I went to look at it in storage. I was inspecting the tires and looked under it to check the suspension and noticed that it has no leaf springs. Is there any maintenance that I need to do to what I have? I've attached a photo.
    https://drive.google.com/file/d/1xrnR_pYf9BLcV1Kp8yKcPxUgwdUYuP3h/view?usp=sharing
  2. Raycfe
    15,856
    1,837
    The axle has no maintenance. But the brakes and wheel bearings still do.
    Family Travels likes this.
  3. Adam H
    Adam H Active Member
    415
    157
    Aug 22, 2015
    Looks as if you have torsion axles.
    Some love them, some not so much, I'm in the not so much crowd....
  4. Family Travels
    25
    Oct 26, 2019
    Illinois
    Thanks! I take it there's no suspension at all then?
  5. Adam H
    415
    157
    Aug 22, 2015
    Originally there was rubber inside and the twisting acted as suspension. The rubber is probably broken down by now so you probably are correct, no suspension left.
  6. Adam H
    415
    157
    Aug 22, 2015
    Is the PUP sitting close to the ground?
  7. Family Travels
    25
    Oct 26, 2019
    Illinois
    I know, probably dumb question but is it still safe to travel or do I need to replace the axle?
  8. Family Travels
    25
    Oct 26, 2019
    Illinois
  9. Adam H
    415
    157
    Aug 22, 2015
    Depends what type and condition of roads you are traveling on. Friend with an 82 Coachman broke his frame it bounced so bad. Also when he replaced his ancient converter with a modern one, the electronics started falling out it rode so bad but these are Calif roads. He did use it that way for years until I built him a frame with leaf springs to sit the PUP on. Sill uses it.
  10. Adam H
    415
    157
    Aug 22, 2015
  11. Family Travels
    25
    Oct 26, 2019
    Illinois
    It is Illinois here so... we only have winter and road work seasons.
  12. bheff
    bheff Well-Known Member
    1,185
    631
    Feb 24, 2011
    NW Arkansas
    Google search torsion axles.
    It doesn't look too low from the pic you posted.
  13. Family Travels
    25
    Oct 26, 2019
    Illinois
    I haven't opened it up since October and we haven't used it yet but when I was pushing on the roof today it was pretty bouncy.
  14. Family Travels
    25
    Oct 26, 2019
    Illinois
    Not the roof. The whole unit was bouncy like an unloaded utility trailer.
  15. MNTCamper
    MNTCamper Active Member
    946
    234
    Jun 14, 2014
    MN
    Can't see your pics as I can't access G drive from work. I have the torsion suspension axles on my '01 Jayco. It rides very nice and tows great. They could go bad over time. The Axle ID and information should be located on the axle itself if you were to need a new one. There was a thread recently on here where someone was replacing their torsion axle.
  16. Sneezer
    1,626
    597
    I have 99 Jayco with torsion axles. Still original on mine, no issues. Tows fine with minimal fuss.
  17. Adam H
    415
    157
    Aug 22, 2015
    Then you should be fine.... Camp on
  18. Anthony Hitchings
    753
    327
    Mar 2, 2019
    Perhaps you exagerate? More likely the rubber has crept under load resulting in less ride height and a harsher ride. Which is why I prefer a regular axle on leaf springs.
  19. Adam H
    415
    157
    Aug 22, 2015
    I'll take that a step further, I would not own a trailer with torsion axles. Something about rubber bands holding the trailer up. Reminds of the saying "held together with chewing gum and bailing wire."
    Anthony Hitchings likes this.
  20. MNTCamper
    946
    234
    Jun 14, 2014
    MN
    Torsion axles work fine, are durable and allow for a lower trailer step in height. It is a proven application used on many trailer suspension systems.
    Family Travels and neighbormike like this.
