Just ordered my Bal
Discussion in 'Leveling Your Camper' started by cssweeney, Aug 9, 2014.
  1. cssweeney
    cssweeney Member
    527
    Jun 26, 2012
    I should be getting it any day. Is it pretty easy to use? Any tips would he helpful. I say this cause I usually camp by myself.
    Candy,
    1989 Coleman Newport
  2. tombiasi
    6,329
    1,881
    I found it easy to use. Depending on how off level you are you may need to do a lot of cranking. Keep the screw lubed and clean.
  3. rcguy
    rcguy New Member
    25
    May 12, 2014
    You are going to like it. You ma g have to crank some unless the site is fairly level but it sure beats driving back and forth on blocks.
    It chocks the wheel securely also. I would not want to be without one.
  4. zendecat
    zendecat Member
    76
    Feb 5, 2012
    Bal levelers are wonderful! Like Tom said, keep the screw lubed for easier cranking. I just crank it up while DW watches the levels. I still have mine in it's original box for transport. I keep it just inside the doorway...first thing to come out when we get to the campsite. :)
  5. ghacker
    ghacker Active Member
    3,438
    Nov 8, 2009
    Very easy to use. Does get tough to crank if you're near the top of the jack screw. If I have to go that high, which is rare, I usually throw a couple of 3/4" pieces of plywood under the BAL before I start using it. I sometimes use a 18v drill with a universal joing and 3/4" socket to speed things up. Still go slow but easier because all you have to do is brace the drill. YMMV.
  6. metro6775
    metro6775 New Member
    73
    Jul 12, 2013
    Best pop up accessory that I've purchased. I do the same as zendecat. I even set my grill on the box to eliminate the grill from sliding on and scratching the linoleum flooring.
  7. kstephens
    kstephens Member
    242
    Jul 28, 2014
    I'm glad to hear this. I just ordered one as well. Thank goodness for this site. Being new to the camper world, I had no clue how to properly level a trailer. I am just two weeks in to the camper, and have a level driveway, so it hasn't been needed. I am taking it out for the first time this coming weekend to a local campground with the family and I will try out the Bal. Luckily, I live in an area surrounded by campgrounds to get the hang of it before we venture to florida in october.
  8. Customer
    Customer Well-Known Member
    2,435
    249
    Jun 5, 2014
    When the Bal is shipped it has a small amount of grease on the threads that is only to protect the metal. DO NOT USE until liberally coating the entire threaded shaft with grease. Many have made the mistake of thinking it was ready to use and destroyed the threaded shaft and socket in only one use!
  9. sleach
    698
    167
    May 17, 2014
    Boulder, Colorado
    KStephens, the BAL is a real nuisance reducer. In return for money and some weight and bulk you get a device that allows you to precisely adjust to side to side level, and re-adjust easily if things have settled a bit after a day. We really like that feature, for many of our stops are not in formal campgrounds.
    We currently stow ours wrapped in a piece of old canvas tarp, but will shortly acquire a pizza deivery bag or sew somthing up out of vinyl fabric. The screw has been greased with wheel bearing grease, and goes in a heavy plastic bag to keep the grease where it belongs. Most any grease will do- Lubriplate (tm) can be bought in a convenient tube and is good for other things that need help sliding around.
  10. Strut
    Strut Member
    250
    Jun 24, 2014
    I just got one and it is great! Probably the best $80 spent on the PUP yet. My stabilizer jacks also use a 3/4" socket so my factory hand crank and/or 18v power drill make quick work of leveling her out.
    Mine stores perfectly on top of the water heater box in the front storage compartment with just a couple of Velcro straps to keep it in place.
  11. banks412
    banks412 New Member
    104
    Sep 18, 2013
    Can I ask where you guys are ordering your levelers from? Any place have a better deal than another?
  12. nancyanddan
    nancyanddan Well-Known Member
    1,490
    28
    Dec 2, 2011
    I ordered our BAL from Adventure RV on eBay. Free shipping, and no sales tax (if I remember correctly).
  13. Dubbya
    6,130
    77
    Aug 2, 2011
    Steinbach, MB
    Keep a close watch on the lift screw and trunnion threads. The first time I used ours with the supplied ratchet wrench, the threads got razor sharp. No problem, I contacted Norco Industries customer support via email. Told them what happened and they sent a free replacement immediately, no questions asked.
    Use plenty of high pressure grease on the screw threads and they'll last.
    Storing the BAL without getting grease all over everything is a problem a lot of owners solve by storing it in a 24"x24" pizza delivery bag.
    I modded mine so the greasy parts store conveniently in an ABS tube that attaches with Velcro then added some homemade clips to hold the frame together while stored.
    You can check out my BAL mod here:
    http://www.popupportal.com/index.php?topic=76590.msg705287
    I use a 1/2" cordless impact wrench with a 3/4" socket and universal joint to crank the BAL up and down in seconds. Some would recommend against it but I've done it all season without any problems. Again, proper lubrication is key.
