Kayaks on PUP Opinions needed.
Discussion in 'Canoeing / Kayaking, Boating, & S.C.U.B.A.' started by RhinoDave, Apr 21, 2009.
  1. RhinoDave
    RhinoDave Active Member
    2,317
    Oct 29, 2008
    Lake Orion, Mi.
    I needed to make up some way of transporting the kayaks with my current roof style since my roof replacement is on hold so I made up some PVC and pool noodle bases to use. I would like some input on what you all think about the design. I've hauled bikes and canoes before but this is the first time out with Kayaks onboard. Any suggestions or ideas would be appreciated. The strapping will be front and rear on each as well as two each from the bases around the kayaks. I also plan on using one or two long straps across the top of both kayaks and fastening under the sides of the PUP. I just didn't have any to use today.
    First pic is the PVC base design without any padding. One side is made higher to compensate for the roof slope so the kayaks will sit level.
    <img src="http://inlinethumb21.webshots.com/18196/2776228830104169197S600x600Q85.jpg" border=0>
    The bases with the padding added.
    <img src="http://inlinethumb29.webshots.com/44828/2570376060104169197S600x600Q85.jpg" border=0>
    Base with kayak set on top.
    <img src="http://inlinethumb42.webshots.com/42409/2840506010104169197S600x600Q85.jpg" border=0>
    Front view with both kayaks.
    <img src="http://inlinethumb38.webshots.com/44069/2755673560104169197S600x600Q85.jpg" border=0>
    With most of the straps in place.
    <img src="http://inlinethumb04.webshots.com/43267/2224750770104169197S600x600Q85.jpg" border=0>
    Built for comfort...not speed.
    97 Coleman Niagara 87 Coleman Sun Valley (project) 08 Chevy Trailblazer
  2. fishguy1313
    fishguy1313 New Member
    346
    Nov 14, 2008
    That looks pretty good. I wouldn't tighten the straps too tight though. Just enough! Good luck!
    2005 Dodge Ram 1500 HEMI - Tow Vehicle
    2005 Fleetwood Utah - Pop Up
  3. TCF
    TCF Van Alstyne, Texas
    26
    Jan 11, 2009
    Van Alstyne, TX
    This worked great for us.
    <img src="http://i175.photobucket.com/albums/w142/texascrappiefisherman/PICT0107-1.jpg" border=0>
    1987 Coleman Columbia
    2003 Chevy P/U
    (2) Ocean Kayak Scramblers
    Jerry & Patty and 2 camping chihuahuas
    Van Alstyne, TX
  4. binky
    binky New Member
    484
    Aug 22, 2007
    Virginia
    TCF, where did you get the rear storage area....and how is it mounted?
    Me and DW circa 1969
    DS circa 1999
    DD circa 2003
  5. BiXLL
    BiXLL Chippewa Twp., Pa.
    650
    Jul 12, 2008
    Chippewa Twp. Pa
    I think you have done a great job of figuring a design and then making it happen, CONGRATS!!!!!
    Bill & Bev
    Andy-16
    Duke and Maggie (4 legs)
    1990 Coleman Clipper
  6. TCF
    26
    Jan 11, 2009
    Van Alstyne, TX
    binky,
    I assume it's factory installed.
    It was on the trailer when we got it.
    It's welded onto the frame underneath.
    2003 Chevy P/U
    Van Alstyne, TX
  7. silvermickey2002
    4,789
    573
    Sep 11, 2008
    Morris County, NJ
    RhinoDave,
    What size PVC pipe did you use? Our son has a 10 ft kayak and I am trying to figure a way of carrying it on the pup roof that will not harm the roof. So far your idea is at the top of the list.
    2005 Honda Ody
    2002 Ford F150 Supercab 4X4
    2008 Fleetwood Seapine
  8. RhinoDave
    2,317
    Oct 29, 2008
    Lake Orion, Mi.
    It's all 1/2"
    BOM is:
    4 pcs 1/2" PVC cut 24" long
    3 pcs 1/2" PVC cut 12" long
    6 pcs 1/2" elbows
    6 pcs 1/2" Tees
    6 Pcs 1/2" PVC cut 1.5" long (I cut three of these at 2.5 to get an angle to match my roof)
    one large pool noodle
    4 pcs of 3/4" pipe foam cut 24" long.
    one roll of electrical tape.
    2 pcs 1" camlock straps 5' long.
    I cut the top lengths so the total length would match the length of the flat area of my kayaks. Since they are 12' the flat area under the cockpit is about 4'. The straps go through the ends and around the kayak to hold the base to the kayak.
  9. nhcaveman
    nhcaveman Barrington, NH
    1,269
    38
    Mar 25, 2009
    New Hampshire
    Hey Binky,
    You can do that to most any popup, well, TCF's does confuse because you cannot see a bumper. But if you do have a bumper, just go to Etrailer and look at this:
    http://www.etrailer.com/p-E-100.htm
    then it's just a matter of a luggage rack for use with any 2" receiver.
    Ive thought about this myself, but I'm already at my max weight for my TV, and don't trust myself, I can already invision myself putting an extra LP tank, extra battery, portable generator, or something else too heavy on there. So think about what you would put on there first, you really don't want a lot of extra weight back there, too much and it could effect how you handle on the road.
    Todd & Emily
    08 Honda Element 4WD - 07 Coachmen Clipper Sport 896S
    http://www.whitemountainboogie.com/nhblues/
  10. silvermickey2002
    4,789
    573
    Sep 11, 2008
    Morris County, NJ
    Excellent, thanks!
    2005 Honda Ody
  11. peanut1
    peanut1 New Member
    Sep 17, 2008
    New Hampshire
    Looks great! When we purchased our popup last fall I had thoughts about carrying our kayaks on our pup. But most of the trips we take we have to travel to where we are going to paddle from the campsite, so we still carry our boats on top of the car.
    1999 Coleman Taos
    2007 Hyundai Santa Fe
  12. Yellowkayak
    2,198
    Mar 13, 2007
    Great design but I only have one concern. Look at the fourth picture. Notice the under edge of your AC unit. When you put straps over the yaks it will push the roof down a tiny but and MAYBE cause the seal around the AC unti to come loose a bit and leak during a rain storm while driving down the road.....notice I said MAYBE. Just something to look at for possible problems, but the rack and idea is sound a great...I like simple, simple always works. Two thumbs up and enjoy your yaks like we do.
    JJ
    Wichita Falls, TX
    USAF Retired
  13. Scott H.
    Scott H. New Member
    Apr 29, 2009
    Mustang, Oklahoma
    Once again, brilliant.
  14. cheyo
    cheyo New Member
    119
    Apr 30, 2009
    SOCAL
    Have I mentioned....i LOVE this site!!!
    Thanks for the ideas!
