Keeping medications cool... :-)
Discussion in 'Camping for the Medically/Physically Challenged' started by WeRJuliIan, Jun 21, 2015.
  1. WeRJuliIan
    907
    90
    May 15, 2014
    Sarasota, FL
    I'm an insulin-using diabetic, and I have to shoot up 5 times a day, so when we camp, I have to haul a supply of insulin "pens" with me.
    Now, insulin, along with probably quite a few other medications, will degrade if it gets hot ("room temperature" is ok, but the maximum storage temperature is 86F, according to the manufacturers and the FDA)
    So I usually take along one of those carrying cases with a slot for a frozen gel-pack, but that has to go back in the freezer every night and, honestly, after a few hours in the sun, I'm not convinced it's doing its job.
    I was wondering if anyone has any experience of using something like the solid state Peltier coolers which will run on 5V from a USB port... (cold beer from your laptop...) My thought was to add a battery and a small solar charger... after all, sunlight is heating it up, why not use it to power the cooling?
    The aim is to have something no bigger than my current gel-pack case, which can stay cool during a day in the sun, away from fridges and power sources..
  2. tombiasi
    5,415
    1,051
    You are in Florida so a Peltier cooler might find it a challenge. I camp with a large cooler. I put 8-10 gallon jugs frozen to -20F in it. Beer and everything else last 6 days easy. I know you want small but with small comes less mass and shorter times.
  3. Byrd_Huntr
    Byrd_Huntr Well-Known Member
    1,224
    272
    Jan 27, 2013
    Minnesota
    If your looking at those little 5v chips, they will get cold on one side and hot on the other. If you don't use a heat sink and a fan on the hot side, the cold side will slowly heat up.
  4. RotnMom
    RotnMom Am I there yet?
    4,125
    19
    Apr 4, 2011
    When my Grandmother was alive, she used a product very similar to THIS
    It seemed to work for her 'all day shop till ya drop days', and she'd even leave it in the car in between stores. This was in Orlando, FL, so you know the heat was ever present!
    [:D]
  5. nineoaks2004
    7,438
    3,187
    Dukes, Fl
    Why not use a cooler, my igloo worked great for the last trip. I just got back from 4 hot days in the 100 deg. and still had ice in frozen bottles, in fact they were still 1/2 full of ice. I took reflectix and made a cover for the cooler and bungeed it over the cover so it would not blow off or get winded off, we had 2 3liter bottles of frozen water, 2 2 liters bottles of frozen tea. Of course the tea was drank but the 2 bottles of water still 1/2 frozen when we got home..
  6. WeRJuliIan
    907
    90
    May 15, 2014
    Sarasota, FL
    If I'm at the campsite, my meds stay in the fridge... I'm looking for something that I toss in the car or a backpack if we go off adventuring for a day or longer.
  7. Customer
    Customer Well-Known Member
    2,436
    243
    Jun 5, 2014
    We use a quality stainless steel thermal bottle (Thermos) with a couple ice cubes inside. Most people use them for hot coffee but they work just as well to keep things cold. It lasts all day.
  8. BarbaraFaith
    BarbaraFaith New Member
    1,447
    Oct 15, 2011
    The newer insulins do not have to be kept cold once they are opened. They are ok for 28 days once opened, and should be discarded thereafter. However, in hot weather, when camping, I will put mine in the 3 way fridge of the PUP or in the outside cooler. Unopened insulins should be kept cold.
  9. scubagirl
    scubagirl New Member
    Jul 9, 2013
  10. rocksncactus
    rocksncactus Member
    325
    May 10, 2013
    Cobb County, GA
    Wow, WeRJulIan, that FRIO pack sounds like just the thing! Looks like it's made from the same thing that's in those cooling bandanna/neckerchiefs that one can buy. The little gel beads swell up with the water and v-e-r-y- slowly release it. It's the same as what's in the soil supplements one can buy at the garden center that help you be able to water plants less often.
    Good luck!
  11. WeRJuliIan
    907
    90
    May 15, 2014
    Sarasota, FL
    ... and, guess what i got for Christmas ? :)
    I shall be experimenting with my new Frio, and I'll let you know how it works out.
  12. WeRJuliIan
    907
    90
    May 15, 2014
    Sarasota, FL
    Well, I said I'd report back... I never said when..
    The FRIO results were disappointing.. I did some tests with a temperature probe inside the pack, and there did't seem to be much cooling effect at all. The pre-wetting and setup is complicated, and the instructions unclear.
    On the whole, I think I'm better off with my ice-pack bag
  13. chuckearnhardt
    chuckearnhardt Member
    30
    Jul 7, 2015
    Someone beat me to it, but I can confirm the usefulness of the FRIO packs. I went on a 3 week trip this past summer out west, and was worried about my insulin. The FRIO packs kept the insulin around 70 all day long (I think they easily could've gone 2, but are easy to "recharge"). I highly recommend them.
  14. kitphantom
    11,856
    932
    Given the difference between your experiences, it sounds as though the FRIO relies on evaporative cooling. Hence the difference in cooling between "the west", where it tends to be arid, and Florida, where it does not.
    One of our friends now has an Epi-pen, and I know she wondered how to keep it cool. It's been a while since she was prescribed it, I'm not sure how she's keeping it cool these days or if she just depends on insulation in her fanny pack or purse. (She lives in AZ, so heat is definitely an issue at times.)
  15. Genie2010
    Genie2010 Active Member
    1,283
    Jul 30, 2013
    You might want to recommend your friend speak to her prescriber-Epipens do not need to be refrigerated. They should be kept between about 60 and 90 degrees F (15-30 C)
  16. kitphantom
    11,856
    932
    @Genie2010 She does know they don't need to be refrigerated. However, when the temperatures are over 100, it is possible for things in packs, purses, etc. to exceed 90. Buried deep in a day pack is pretty safe, but in a fanny pack, etc. things can heat up.
