1. SaintPaulRookies
    SaintPaulRookies New Member
    May 5, 2015
    I am wanting to get a couple copies of the key used for our camper. I stopped at a big box store and local hardware store, neither of them were able to help me. Called the local camper/trailer store to see if they cut keys and said they don't.
    Any suggestions as to who I can contact to get a couple keys made?
  2. Halford
    Halford Well-Known Member
    3,563
    559
    Sep 28, 2011
    Santa Clarita, California
    First of all Welcome to PopupPortal... Can you put your camper and TV information in your signature? that way we know which information you need...
  3. mrjam2jab
    mrjam2jab Member
    83
    May 29, 2014
    was the "camper/trailer store" you went to a dealer? If so, I'm really surprised they couldn't help you.
    When I needed a key for my pup, I called the local dealer. They don't cut the keys themselves, but they use a local Ace Hardware store. So they sold me one copy and said if I needed more Ace is the place to go.
  4. bropaul
    bropaul New Member
    4,830
    Aug 7, 2009
    X2 on Ace
    Paul
  5. SaintPaulRookies
    May 5, 2015
    Thanks. I've added it now.
  6. SaintPaulRookies
    May 5, 2015
    I stopped at Ace, and they said they weren't able to help me. I will try one other location and see what they can do.
  7. daschnoz
    daschnoz Active Member
    273
    56
    Feb 9, 2015
  8. Byrd_Huntr
    Byrd_Huntr Well-Known Member
    1,224
    270
    Jan 27, 2013
    Minnesota
    Is there a number stamped on the key or the lock, if so use that to order a new one online.
  9. kitphantom
    11,752
    852
    Welcome.
    For both our 2010 Coleman pup and our 2015 Retro, we had no problems getting extra keys made at the local lock and key shop we use. In fact, we actually bought new lock inserts and keys for the storage locks on the TT, so they didn't use the same key lots of other campers use.
  10. nineoaks2004
    7,306
    3,040
    Dukes, Fl
    I get mine at ACE Hardware.. Most side hatches (and some entry) are # 751
  11. F239141
    F239141 New Member
    285
    Jul 19, 2014
    I had to go to a locksmith to have mine made, still really cheap
  12. Hoosier Daddy
    Hoosier Daddy Active Member
    1,331
    Jun 24, 2014
    This is odd. Camper keys are usually realy basic and most of the times a blank that is redilly available. Like was asked earlier, does you key have a number on it? That is likely the blank you need. The local HWI Do-it had it for my 2000 Coleman.
  13. mrjam2jab
    mrjam2jab Member
    83
    May 29, 2014
    Is it an original lock?
    If so, for your year it should be an 1101x key
  14. SmilinBeard
    SmilinBeard Member
    507
    Feb 18, 2008
    Email Beckley's RV at www.colemanpopupparts.com or call (800) 653-3054. They should be able to help you as they bought out all Coleman's stock when they quit production. Coleman only used two keys in all the years they were in business. Mine is number 8025. Not sure when they changed to that number. Per mrjam2jab yours should be 1101.
  15. mjsny
    mjsny Member
    197
    Aug 14, 2013
  16. cattitude
    cattitude New Member
    31
    May 14, 2015
    If you cant find one, you could change the cam locks (the center core of the lock). I just did that cuz the keys were bent and the inside of the cam locks were all loose. For 4 cam lock things I paid $20. It wasn't a hard job to do either!
  17. JustMePatrick
    JustMePatrick Member
    77
    Jun 24, 2013
    Try a local locksmith, they can probably make the copy.
  18. TDS-MN
    TDS-MN Active Member
    471
    48
    Sep 29, 2013
    Minneapolis, MN
    I think that further exploration for another local hardware store should be helpful. When we got our jayco a couple years ago now, the P.O. did not know where any of the keys still were. Not wanting to leave it at that, I went to a local dealer (Hilltop) with the number I took from the lock cylinder. Found a key in their box that matched. It was crazy-expensive, over $8, but I took that one, and went to my local Ace, and they had the same key blank, and cut me a few more, at something like $2.50 each.
  19. mrjam2jab
    mrjam2jab Member
    83
    May 29, 2014
    I just looked at the copy i had made...it is Key Blank AP1...if that helps at all.
  20. arthuruscg
    arthuruscg Active Member
    1,363
    Nov 14, 2012
    Most big box stores cross reference off of the number on the key. For most keys the number refers to the key blank but on trailer keys the number is the actual key and cut.
    You can look up and order the key based on the number on the key.
    Sent from my XT1060 using Tapatalk
