LED lights?
Discussion in 'First Time & New Camper Owners' started by cajunsticker, Jan 22, 2009.
  1. cajunsticker
    cajunsticker New Member
    Sep 9, 2008
    Has anyone switched their lights to LED? Do they even make such a thing? I was thinking that it would be good for extended boondocking during hunting season.
  2. Twisty
    Twisty New Member
    4,375
    Aug 24, 2008
    Hillsboro, Oregon
    Check out the electrical forum - tons of info!
    http://www.popupportal.com/topic.asp?TOPIC_ID=13258&FORUM_ID=51&CAT_ID=18&Topic_Title=New+Led+Light&Forum_Title=Electrical+%2D+Site+Power%2FBatteries%2FGenerators%2FSolar
    2004 Fleetwood Utah w/slide
    2006 Ford Ranger 4x4 Ext. Cab
    www.CWhatIC.net
  3. cajunsticker
    Sep 9, 2008
    Thanks,
    That's exactly what I wanted.
  4. dirtyboy
    dirtyboy New Member
    369
    Dec 11, 2008
    Cajun, I just picked up some lights from Autolumination that are pretty bright.....
    I have one that is 96 LEDs that I am going to use for a porch/scare light and a 24 led light to use for a dome inside....
    I also have some motion activated spot LEDs inside for additional lighting over the table and kitchen areas.....
    I would start here http://autolumination.com/fixtures.htm
    Try it in a Toyota!
    '74 Coleman Yorktown under construction......
    Tow Rigs =99 Toyota 4runner and 93 Pickup (Rockcrawler)
  5. Mr_Custom
    Mr_Custom Member
    847
    Jul 14, 2006
    Sudbury, Ontario
    In our pup I changed one of 2 bulbs in each of the overhead lights to the LED arrays. When we have street power I leave both intact; when we dry camp I pull the incandescent bulbs to conserve power. It has worked well so far. Eventually I will probably change them all out.
    Mr_Custom (Rick)
    2005 Chev Trail Blazer -2003 Coleman Sun Valley
  6. riverwalker
    riverwalker New Member
    295
    Jul 25, 2010
  7. Richard
    Richard Take kids camping. It's great for you and them.
    278
    Dec 11, 2007
    Blue Ridge Mountains, Tennessee
    I have the delusions that I will do some dry camping (no hookups) and that conserving battery power will be important. Still, I find the prices of 12-volt LED bulbs that will go into the 1156 socket in my dome lights to be way too high.
    I picked up a LED array in Lowes (in the light bulb isle) for $8.99 plust tax. It is designed to replace a halogen bulb in landscape lighting. It is 12-volt, though the package doesn't say so.
    I took the old 1156 bulb down to just the brass, and did a little engineering to create a two-prong socket within it. I put the base in, and the LED array plugs right in. Almost as much nice white light, and no heat. I love it.
    Here's the engineering. I had a female CATV outlet in my junk box. This one wasn't a double female, but instead had a lead in the center to attach the center wire of the coax. I trimmed this down to a small nub. I covered the bottom with a disc of electrical tape, with the nub sticking through the center. I reamed out the hole in the bottom of the 1156 brass and inserted the female CATV outlet end. The nut that came with it went on inside the brass to hold everything tight.
    One leg of the LED bulb/Array plugs into the center hole, and the other rubs against the threads of the female end. It works great and stays in place.
  8. Travelhoveler
    Travelhoveler New Member
    2,337
    Mar 8, 2011
    We replaced all our camper lights with LEDs. Love them. Light is as bright and same color balance as the bulbs they replaced, but they don't add heat, and running every light at once, including outside ones, draws much less power than any single bulb they replaced. If you do lots of boondocking and dry camping, it's the way to go.
  9. Richard
    278
    Dec 11, 2007
    I'm working to get things ready for boondocking in the Cherokee Nat'l forrest by next season (Maybe this season). You have inspired me Travelhoveler.
  10. screwballl
    screwballl Stimulus Package
    642
    Aug 7, 2009
    FL
    As time and money provide, I plan to start replacing all the bulbs on my pup to LEDs. I will be starting with the brake lights since the ones on there now are so dim it is hard to see during the day.
  11. Travelhoveler
    2,337
    Mar 8, 2011
    You're going to love it. And don't forget the Pisgah, Nantahala, and George Jefferson national forests just over the line in North Carolina and Virginia.
  12. Richard
    278
    Dec 11, 2007
    I've got to get the "food smells" out of the camper too (curious bear phobia). Not sure if that's possible. I've used the stove, etc. inside a lot over the years. Never planned to take the PUP beyond the campgrounds when I did that. Oh well...
  13. austinado16
    austinado16 Proud Starcraft Owner
    129
    Jun 9, 2007
    4 seasons ago, I replaced all 4 of our ceiling bulbs (2 per fixture) with the "warm white" 92 lumen 9LED 1156 boards from www.superbriteleds.com. I also replaced the porch light with their amber 16LED 1156 board. They've all held up well and the light output and color spectrum is excellent.
