LED's not working
Discussion in 'Road Safety Systems' started by mickeytopher, Aug 10, 2020.
  1. mickeytopher
    mickeytopher Member
    109
    May 20, 2013
    After nearly catching the camper on fire I decided to replace the 1157 brake light bulbs with LEDs. The two on the interior work fine, but I can't seem to get the bulb on the outside light to work. If I stick it in the very end of the socket it will work, and any further it becomes very dim. The original bulb works fine in that same socket.
  2. nineoaks2004
    8,241
    3,686
    Dukes, Fl
    check polarity
  3. Scott And his Popup
    Scott And his Popup New Member
    Aug 10, 2020
    Ottawa, Ontario, Canada
    This does sound like polarity, or maybe an LED mismatch? Some sellers (particuarly at the lower end of the $$ range) will claim their bulb works for your application, but wont, or won't work without modification. This is particularly true with bulbs that are both brake light/tail light and turn signal. as there are different filaments in the incandescent for brake/TS vs taillight, the LED has to be able to do all 3.
