Leveling a Twin Axle Hybrid? Andersen Doesn’t Fit!
Discussion in 'Leveling Your Camper' started by JunkyBurrittos, Sep 6, 2019.
  1. tfischer
    tfischer Well-Known Member
    3,490
    996
    May 21, 2014
    Go figure, when you give a product an improper name, people tend to think it does what the name says.
  2. GreyFox
    GreyFox Well-Known Member
    1,304
    589
    Oct 10, 2018
    S Ontario
    Yep, go figure - but even when Norco includes a warning note in every box of X-Chock(s) sold many still ignore the warning and use them as "chocks" anyway. [B)] FWIW though, a pair of X-Chocks do noticeably reduce camper wiggle.
  3. Sjm9911
    4,356
    2,181
    I tent not to read stuff, especially when im waiting for it in the mail. Lol. I would have never thought they wernt for chocking the rig.
  4. tfischer
    3,490
    996
    May 21, 2014
    That's like buying something called a "battery" but it's not intended to be connected to your electrical system, but instead provides additional tongue weight to help with towing.
    If it's not a chock, they shouldn't call it a chock. Then there would be no need for a warning to ignore.
    Sjm9911 and neighbormike like this.
  5. JunkyBurrittos
    JunkyBurrittos Active Member
    343
    80
    Mar 18, 2017
    Central MA
    Thanks Mike. I'll look again when I'm not so straight out. Are you hacking off the tall end and using the shorter end? I'm trying to envision how this does not detract from the total height you can attain from these. Thank you!
  6. shelmily
    shelmily Well-Known Member
    3,294
    274
    Jun 7, 2012
    Northeast Pennsylvania
    Donna, you need to cut off the narrow end of the ramp, not the fat end. It really doesn't detract at all. The little bit you cut off is so thin it wouldn't raise the trailer much anyway.
  7. JunkyBurrittos
    343
    80
    Mar 18, 2017
    Central MA
    Ok thanks Mike!
  8. Dingit
    Dingit Well-Known Member
    839
    372
    Mar 8, 2017
    For what it's worth, I've broken plenty of Lynx blocks, but I'm subjecting them to more weight than a standard TT...expect all plastic to fail every so often. :)
  9. Sjm9911
    4,356
    2,181
    I caved and bought the cameo wedges. I'll post when they come in.
  10. JunkyBurrittos
    343
    80
    Mar 18, 2017
    Central MA
    I think i'm going to order mine today too. I tried sawing away at my Andersen yesterday and I just don't have the time to devote to slowly removing 4" from a product they said would work. My kids were crying to be fed and I gave up. Crazy priorities right? [:P]
  11. GreyFox
    1,304
    589
    Oct 10, 2018
    S Ontario
    On uneven ground surfaces, sure - but mounting Lynx on a rigid base solves this issue entirely.
  12. Snow
    10,040
    980
    I have done similar to Greyfox.. except I haven't screwed the base set of blocks to the board, I just made an end stops so the blocks won't slide off. This might be something I do next year.
    FYI: Lynx Levelers carry a 10 year warranty...
  13. tfischer
    3,490
    996
    May 21, 2014
    Haha what were you using, a butter knife? LOL
  14. Dingit
    839
    372
    Mar 8, 2017
    Ha! If I could fit boards into my leveled-by-Lynx rig I'd be using boards!
