Lift effort on newer pups
Discussion in 'Camper Pre-Purchase Questions' started by eoleson1, Mar 29, 2019.
  1. eoleson1
    eoleson1 Well-Known Member
    3,019
    1,224
    Jul 5, 2011
    Macomb County Michigan
    As you can see from my signature, I've been camping in a 94 starcraft pop up. We are looking to replace it, and I'm thinking about trying to find something with power lift, but I don't know if that should be a deal killer. Can anyone clue me in on the difference in effort lifting the roof on a newer pup compared to something about a quarter century old?
  2. soft 17
    soft 17 Active Member
    253
    110
    Mar 14, 2017
    San Luis Obispo
    I just flip a stich and the roof goes to the top. Zero issues with my 2018 model. It was a deal breaker for me to have a power roof.
  3. SteveP
    SteveP Well-Known Member
    1,752
    542
    Lift systems haven't changed in the last 24 years. If anything a newer pup should be easier because the lift system will not be as worn. The major difference would be the weight of the roof itself.
  4. BikeNFish
    BikeNFish Well-Known Member
    3,513
    2,363
    Apr 24, 2017
    Maplewood, MN
    I have one on my pup. Don't make it a deal breaker. I think they are over rated. My pup has a 10' box, but may be more of an advantage on a pup with a 12' box.
    I like it but it can be very touchy. I found that unless the pup is perfectly level and the stabilizers are not deployed until after the roof is up, it works well. Any variation and the motor struggles. I have already decided that if the motor ever fails, I will replace it with the manual crank. Another worry is that the toggle is available for any curious kid to be tempted to try it out. There is extra maintenance (grease) that you have to do. Not difficult, but just one more thing to worry about.
    I had to replace my toggle switch shortly after I bought the pup. Again, not a difficult task. The cost was $10 from Grainger, but the local RV service center wanted $59 for the exact same part.
    If the motor fails, the manual bypass will need 2000+ cranks to lift and lower the roof. I keep a cordless drill handy in case of the malfunction to use instead of the hand crank.
    Mat Kyne likes this.
  5. neighbormike
    2,813
    2,592
    Oct 6, 2012
    WI
    I started out with a '94 Stardust 1021... the lift system was much better built and smoother operating than my '14 Jayco. The '94 was also a much better built camper! My advice: before upgrading, make sure it is truly an upgrade!
  6. PopUpSteve
    PopUpSteve Administrator
    19,570
    2,195
    Dec 22, 2002
    Malvern, PA
    A good nights sleep with no back pain.
  7. wusthof
    wusthof Active Member
    119
    31
    Apr 24, 2012
    Vancouver, Canada
    [LOL]
    [LOL][LOL][LOL]
  8. Dingit
    Dingit Well-Known Member
    1,092
    586
    Mar 8, 2017
    My current one has a power lift and I haven't tried it with a crank. (I had a manual lift on a '74 Apache which uses an entirely different lift system and it was absolutely effortless--felt like the crank wasn't attached to anything but the roof and walls went up anyway. :p )
