Lift post covers
Discussion in 'Lift Systems' started by timo4352, May 22, 2014.
  1. timo4352
    timo4352 New Member
    23
    Oct 15, 2013
    We bought our'97 Palomino Yearling last fall. Never got to use it before winter set in, but I did have it setup to check it out. Well today I got it out and set it up again. My question is concerning the lift post covers - the 3 sided, U-shaped tubes that fit over the lift posts when they are extended. I only found two in the camper - should I have four - one for each corner post? Or maybe just one on each side - diagonally? As in right/front - left/rear? Or should I be looking to buy two more so I have one on each corner? Thanks for letting me ask my silly newbie question. [::)]
  2. camper2009
    camper2009 New Member
    367
    May 29, 2012
    Two only, installed as you noted..
    G
  3. Aunt Ness
    Aunt Ness Member
    279
    May 13, 2012
    We were only given when we purchased our 2013 from the dealer last year. So you are good with just 2, and place them diagonally.
  4. timo4352
    timo4352 New Member
    23
    Oct 15, 2013
    Thank you. That's what I was hoping to hear. [:)C]
  5. Rynderz
    Rynderz Lifelong Camper
    1,953
    Aug 5, 2011
    SE Wisconsin
    If you have a one piece door - not familiar with your particular pup- then it is also designed to assist in keeping the roof up. [2C]
  6. sandyjoeville
    sandyjoeville New Member
    Jul 15, 2014
    Our new-to-us 2000 Jayco Qwest 10x camper did not come with any lift post covers. My husband has cut four 1 x 2 pieces of wood and we zip tied them to the lift posts once the top was up on our maiden camping trip this weekend. He is afraid the cable will snap and the roof will come crashing down and squash us. Where is a reliable place to purchase replacement lift post covers? Do I need two or four?
    Thanks!
  7. friartuck
    friartuck Well-Known Member
    2,863
    112
    Nov 1, 2007
    Perry, MI
    Welcome to the Portal Sandy! What hubby did is just fine, no need to buy the safety posts, even using wood you are fine. If you feel you need to go with metal you can find something suitable at the hardware store. And you do only need two on a diagonal as described above.
  8. tconroy
    tconroy Active Member
    1,648
    Apr 25, 2013
    I do right rear and left front because the door is in the left front to help support. If you need more they are only 14 bucks a piece.
