lift support post tore out of wall
Discussion in 'First Time & New Camper Owners' started by Sagale, Mar 23, 2017.
  1. Sagale
    Sagale New Member
    Feb 3, 2017
    1998 Palomino fold a wall
    Lift support arm came out of the wall leaving four holes.
    How do I fill the holes so they will support the weight and pressure from the lift post (Goshen lift system) 17493085_10212582428294328_7357261984110125834_o.jpg
  2. durhamcamper
    durhamcamper Active Member
    746
    198
    Apr 21, 2010
    Pickering, Ontario
    Usually the reason this happens is because of water damage/rot to the sideboard. Water intrusion is very common in this area when the caulking breaks down over time. You may need to replace the sideboard to get the strength required to hold the screws and support the roof. The roofs on pups are fairly heavy.
  3. Sagale
    Sagale New Member
    Feb 3, 2017
    I should have stated that the problem first happened when i lifted it with the winch but left that corner latched. The original pole and bracket was ruined.
    The holes were stripped/ruined and i *THINK* that they just need to be prepped so I can use them again.
  4. steve7-4
    steve7-4 'I'd rather be camping'
    154
    Aug 26, 2014
    Northeast Illinois
    If you need a fix for a short time, add a piece of aluminum plate to the outside and use nuts/bolts to secure. The wood does need to be replaced, Looks like the screws just pulled through the rot. Good luck!
  5. Sagale
    Sagale New Member
    Feb 3, 2017
    Thanks. I will start with a quick fix then shore it up as i get time.
  6. durhamcamper
    746
    198
    Apr 21, 2010
    Pickering, Ontario
    If the sideboards are not rotted and in good shape then drill the stripped holes to almost the thickness of the board. (don't drill completely through). Cut some dowell the same thickness as the drill bit and glue into place (completely filling the hole). Let the glue dry completely and re-drill the center of the dowell in order to accept the screws from the bracket.
  7. 2001dennycoleman
    2001dennycoleman Member
    128
    Jun 28, 2014
    Amarillo, Texas
    The Dowell idea is a good one. Kinda like a hela-coil for metal.
  8. Sagale
    Sagale New Member
    Feb 3, 2017
    Will try dowels first. Goshen company said also that the post was backwards. Will correct that too. This is a learning experience alright!
  9. MNTCamper
    MNTCamper Active Member
    907
    202
    Jun 14, 2014
    MN
    IF the above things don't work for a fix, there is nothing wrong with bolting through the wall as long as you do a good job waterproofing the external penetrations. The addition of an external or internal plate to help with support if the wood integrity is low.
  10. Sagale
    Sagale New Member
    Feb 3, 2017
    Dowels didnt work. Will move on to taking inside skin off and looking at the wood.
