Lift won’t lift
Discussion in 'Lift Systems' started by Ntk37, Aug 26, 2019.
  1. Ntk37
    Ntk37 Member
    37
    25
    Jun 7, 2019
    Took the PUP in for some work, got it back and the power lift wouldn’t close bc the tech said the batteries were so drained. He used a drill to crank it down.
    Charged the batteries (checked voltage, reading at 13), still nothing. Can’t crank it or use drill to open bc when hubby tried the TOP OF THE SCREW popped right off.
    We know nothing about wiring on these things, but he is an electrician so he has some basic wire knowledge (he’d be so flattered I said that, lol). They swapped out the kill switch when they removed the kitchen in the shop, is it possible that has something to do with it? The radio in the camper turns on, if that’s worth anything.
    2007 Rockwood Premiere 2516G
    I assume if I bring it into the shop they have some way of opening it?
  2. MintHillBill
    MintHillBill Member
    135
    Jun 11, 2008
    MintHill NC
    A bit late, but I just read this. I have a Working electric winch that I took out of mine. Has a bent winch frame but still works ok. Will send to anyone for the postage. I used it for 2-3 trips before I replaced it with a new ($300) one. Long story on how it bent, but ir started with a dead battery,
  3. Grandpa Don
    Grandpa Don Active Member
    465
    227
    Sep 5, 2018
    Can I see a photo of that winch? Can you estimate what postage would be to California?
  4. MintHillBill
    MintHillBill Member
    135
    Jun 11, 2008
    MintHill NC
    Let me take on in daylight tomorrow. I'll figure postage too (probably Priority mail box).
    Bill
    Grandpa Don likes this.
  5. MintHillBill
    MintHillBill Member
    135
    Jun 11, 2008
    MintHill NC
    4337858E-D34B-45C2-9D74-185B7B856587.jpeg Here are pictures. One highlights the area bent. Weight 16 lbs. scale off by 1.75.
    ups is 41 fedex 40, usps 59! Has cables and up/down switch. Plug n play! 5AF36181-C0B4-4DE0-BB33-A54D094BFD0D.jpeg D470B5C8-38F6-4CCD-9C65-F10059CCFEED.jpeg
  6. Grandpa Don
    465
    227
    Sep 5, 2018
    Damn! That winch is different from the one that I have. Thank you, but I'm afraid I'll have to pass. Surely someone would be interested.
