Lifting a 1986 Palomino Shetland
Discussion in 'Taking Your Camper Off Road' started by Brevyn Mettler, Jan 28, 2020.
  1. Brevyn Mettler
    Brevyn Mettler New Member
    Jan 15, 2020
    I have been trying to navigate the portal but seem to keep going around in circles. Has any lifted a shetland without major frame modification? If so, can you guide me to the thread or provide some insight into aftermarket kits, tire/rim sizes, etc.
  2. the-one1
    the-one1 Member
    69
    58
    Apr 6, 2016
    Matter of fact I just did that 2 weeks ago.
    I did an SOA and will be replacing the small 8" wheels with 12" come summer.
    Lots of penetrating lube for the rusted nuts on the U bolts. Had to use an impact gun as they were quite stubborn for being 37 years old. (1982 Shetland). I just bought new spring perches and U bolts from Tractor Supply.
  3. Brevyn Mettler
    Jan 15, 2020
    Was it pretty straight forward? I just purchased the from e-trailer. Which 12" rim/tires are you doing?
  4. Arruba
    Arruba Well-Known Member Gold Supporting Member
    693
    361
    Nov 28, 2014
    Central Oregon
    It’s pretty straightforward if you can weld, or find a good welding/fab shop. Most trailers that use a leaf sprung axle have a bend in the center of the tube to set the camber for the tires. Thus just rolling the perches to the top usually can’t be done. Getting some lift for rough country really does help. Good luck with yours.
  5. Raycfe
    17,761
    3,252
    If you have leaf springs and the springs mounted to the underside of the axle. You can add new springs saddles to the top off your axle and mount the springs so the axle is on the bottom. You should keep the axle top just as it is, don't just try to flip it. Most axles will have a"bow" to them and that position has to be kept. Thats way new mounts and needed. And if haves brakes the right side has to stay on the right side etc.
    As suggested Lub everything up, but plan on new Ubolts and the saddles.
  6. joet
    5,015
    1,080
    The new saddles must be tac welded to the axle. Braking action will cause the axle to roll, no matter how tight the u-bolts are.
  7. the-one1
    the-one1 Member
    69
    58
    Apr 6, 2016
    A Shetland doesn't have brakes.
  8. Brevyn Mettler
    Jan 15, 2020
    I appreciate all the help. Does anyone know if I will be able to fit a 5.30 X 12?
  9. the-one1
    the-one1 Member
    69
    58
    Apr 6, 2016
    Mostly likely I'll go with 12" wheels from Northern Tools or etrailer. Not sure on the exact tire brand yet. Visually I think it will fit. But if I buy locally, at least I can return them if they don't fit.
  10. Anthony Hitchings
    3,056
    1,809
    Mar 2, 2019
    Oakland, California
    we paid $100 to get our new perches welded to the axle, no regrets. Got beautiful welding.
  11. Anthony Hitchings
    3,056
    1,809
    Mar 2, 2019
    Oakland, California
    Measure the available edge distances to center of axle, and compare to computed outside of your anticipated new wheel purchase. I did, and it did not work out for me to use bigger wheels.
