Lighting
Discussion in 'Lighting, Interior and Exterior' started by JJCT, Aug 13, 2019.
  1. JJCT
    JJCT New Member
    Aug 13, 2019
    Hi My husband and I just started camping with our new pop up. We have all the necessities we think we need except for adequate exterior lighting. Does anyone have any ideas ? My husband wants to hook up something permanent thru the electrical system. Thanks
  2. tombiasi
    5,842
    1,412
    What do you want to light?
  3. JJCT
    JJCT New Member
    Aug 13, 2019
    Want to hook up a small light to the outside of camper thru a 110 volt outlet inside camper
  4. Sjm9911
    6,453
    3,808
    Just remember, lights bring bugs!
    WVhillbilly likes this.
  5. Annunzi
    Annunzi Member
    42
    Jun 14, 2019
    Vancouver Island, British Columbia
    We converted our exterior light to LED and it's enough to light our 8x10' exterior mat. For the picnic table, we use a Coleman LED lantern, been using it for 3 years and still haven't had to replace the batteries:
    https://www.amazon.com/Coleman-Twin-LED-Lantern/dp/B07BWFX193
    When connected to shore power, we'll also run some LED edison string lights around the awning
  6. JJCT
    JJCT New Member
    Aug 13, 2019
    Very True...
  7. tombiasi
    5,842
    1,412
    I don’t understand why you don’t just plug in a light. Does your pup have an outside outlet?
  8. JJCT
    JJCT New Member
    Aug 13, 2019
    No outside outlets. Want to run the wire from an inside outlet thru the outside wall and mount a light
  9. tombiasi
    5,842
    1,412
    So what’s preventing you doing that?
  10. JJCT
    JJCT New Member
    Aug 13, 2019
    Having a tough time finding a low profile outside light 120v
  11. jmkay1
    5,503
    2,282
    I haven't put it on yet, as the weather or time never cooperated. I bought a multicolor LED light strip. I was going to put under the awning and fish it through a hole in the canvas where the canvas meets the roof. From there I could easily hook an extension cord to an electrical outlet. The only problem is I can't use it off grid. The multi color LEDs allow me to switch it from white to another color if I don't need the white light.
  12. JJCT
    JJCT New Member
    Aug 13, 2019
    That would def work but would rather have the cord hidden which is possible . Some work but would be a permanent solution. Just can’t locate a light with the 120v
  13. Sjm9911
    6,453
    3,808
    If your staying at ellectric places, just run a cord under the pup from the pedistal. Easier then hard wiring it. Or just install a plug on the outside of the pup for lights. That way you can plug in other stuff also.
    kitphantom likes this.
  14. kcsa75
    kcsa75 Well-Known Member
    3,647
    1,850
    Sep 9, 2013
    Kansas City
    You're camping. These will provide all the light you need.
    bobinfleet, gladecreekwy and Sjm9911 like this.
