Linksys wireless Router for PC Card
Discussion in 'Campsite Electronics' started by outdoorxman, Sep 9, 2009.
  1. outdoorxman
    outdoorxman The mountains are calling me and I must go.
    418
    Jul 31, 2006
    Kansas City Area
    A friend of mine is mixes camping with business. They will camp if they are going to trade shows. While away from the home office they need Internet access. I saw a few years ago someone on here added a Linksys wireless router and monster antenna to their PU. The router was designed to accept a wireless PC data card from one of the wireless carriers. I think it was on a Fleetwood E model. I can't seem to find the pictures any more. [?:~{] If you are still around can you re-post with a description?
    Thanks.​
    Phil
  2. Albert and Melanie
    Albert and Melanie The "pup" Palace
    1,041
    Mar 30, 2009
    Oklahoma
    If he has a wireless card, are you sure he will need a router? DH has a wireless for his laptop through AT&T, he doesn't use a router.
  3. PopUpSteve
    PopUpSteve Administrator
    19,403
    2,068
    Dec 22, 2002
    Malvern, PA
    That would be grcooperjr. I also have a Linksys wireless router and a 3G card. It works great and if I had a booster and antenna it would be even better. I also tried to use a web-cam with it to do a live feed from a rally but I could not get it working correctly. I did have it setup at one rally for others to use as a WiFi but the range on the Linksys wireless router sucks.
  4. samtgrizz
    samtgrizz New Member
    869
    Jun 3, 2009
    San Antonio, Texas
    Verizon has a new card that will allow you to share with 5 other users. Otherwise if you have a 3 G Card here is a link to the Linksys card.
    http://www.beachaudio.com/Linksys/Wrt54g3gv2-St-p-156581.html?utm_source=froogle&utm_medium=cpc&utm_campaign=wrt54g3gv2-st&utm_content=atr
  5. grcooperjr
    grcooperjr Lunatic
    1,520
    May 21, 2007
    Tigard, OR
    Hi Phil....
    Like Steve said......It was me. Here is a link to what we have. Verizons new card does the same but the brodcast range is linted and only 5 users can connect,
    What I have works really well. I also brodcast the wifi connection to the campground. It has a range of around 3000 ft or so but it depends on the laptop antenna.
    This setup works way better than the Sat system we use to rent and way faster speeds.
    Hope it helps....
  6. outdoorxman
    418
    Jul 31, 2006
    Kansas City Area
    Ray, I was wondering if it was you but I didn't want to name names if I was wrong. Thanks for the link. I will forward it on! I have the Verizon PC card and it works for me but they tend to stay in NP CGs. They are usually more remote. Yes, we have those in Missouri! lol
    One of the great things about this site is the friendliness and helpful attitude that everyone gives. Thanks again to all that replied.
    Phil
  7. turtle
    turtle New Member
    564
    Feb 14, 2007
    I also must keep in touch with work issues 24/7. I use a Sprint air card and have always been able to connect. At times only 10% signal and very slow but does what I need. I still consider camping getting away as I'm not bothered unless absolutly necessary which is different from my non camping schedule.
  8. grcooperjr
    grcooperjr Lunatic
    1,520
    May 21, 2007
    Tigard, OR
    Hi again Phil.....
    The main reason I did what I did was:
    1. we needed a way to connect in remote areas. Cells don't normally work well. The antenna and amp solved that issue.
    2. needed to be able to connect a large group of campers to the web for there needs. If there just checking mail and keep file size small the speed works GREAT.
    If your only connecting one PC, the router really is not needed. It is nice to have a hardware firewall device but it adds a $200 or so expense.
  9. screwballl
    screwballl Stimulus Package
    642
    Aug 7, 2009
    FL
    one thing to remember is that most carriers have moved away from the PC card connections and are using USB based setups.... but my experience as a computer tech is that USB based internet connections are buggy at best and refuse to work at the worst...
    as for routers, here are a few:
    http://www.buy.com/prod/linksys-wrt54g3gv2-st-wireless-g-router-for-mobile-broadband/q/loc/101/209246437.html
    http://www.beachaudio.com/Dlink/Dir-451-p-116263.html?utm_source=froogle&utm_medium=cpc&utm_campaign=dir-451&utm_content=atr
    http://www.beachaudio.com/Dlink/Dir450-p-88460.html?utm_source=froogle&utm_medium=cpc&utm_campaign=dir450&utm_content=atr
    and with the standard antenna connector on the Linksys (DLink usually has fixed antennas)... it should be easy enough to put a larger antenna on top for a shared connection.
  10. You-And-I
    You-And-I Ozarks Überland Basecamp
    861
    Jan 3, 2007
    St. Louis, MO
    What do you think of this set up?
    Wilson Wireless Amplifier "Booster" #801213 W/Cradle Kit
    RV / Trucker Spring-Mount Cellular Antenna (301133)
    MiFi #2200 Intelligent Mobile Hotspot
    The Mifi unit slides into the Wilson Cradle and now you have wireless Wi-Fi,
    the MiFi has a 30ft. range and simultaneously allowing up to five computers
    or personal devices to be connected.
  11. grcooperjr
    grcooperjr Lunatic
    1,520
    May 21, 2007
    Tigard, OR
    looks like it would work....
  12. You-And-I
    861
    Jan 3, 2007
    St. Louis, MO
    grcooperjr,
    We are trying to figure out how to make this work, we can bolt the Wilson Antenna on top of our Jeep rack. Do you think our CB antenna would interfere with the Cell/Internet antenna reception? We also have a radio amplifier under the drivers seat, I can mount the Cell/Internet amplifier under the passenger seat or under the dash to keep it away from the other amp. Any ideas would be appreciated.
    Thanks Phil (Outdoorxman), for starting this thread.
    Alan
  13. grcooperjr
    grcooperjr Lunatic
    1,520
    May 21, 2007
    Tigard, OR
    Hi Alan....
    as long as you got a little distance between antennas you should be ok. I don't think the pattern will be afected by a whole lot. The bigest difference in reception is height. In most of my remote locations the difference between ground level and 25 ft is a bunch. As a result the bandwidth avilable goes up with the signal level.
    Another side benny of what your doing is it will also help a normal cell if needed.
  14. outdoorxman
    418
    Jul 31, 2006
    Kansas City Area
    Hey Alan, I was asking for you and I'm glad you were watching this post! I agree with Screwball, USB devices are flaky! I have had my share as well being an IT Manager and having to support all kinds.
    Looks like you've done your research. I bet that Jeep will look like a giant bug when complete. LOL Will Chris be happy with it? As long as she has a connection! See ya this weekend.
    Phil
  15. You-And-I
    861
    Jan 3, 2007
    St. Louis, MO
    grcooperjr,
    Thank you for all your help, I'll post some pics after I get everything installed.
    Alan
  16. You-And-I
    861
    Jan 3, 2007
    St. Louis, MO
    Outdoorxman,
    Thanks for your help on the cell Amp post. We are looking forward to seeing You & Tammy and your new camper. "Congrats"
    Happy Birthday Tammy!
    Alan
  17. Kevin 11-RT
    Kevin 11-RT New Member
    56
    Jul 12, 2009
    Eugene, Oregon
    I am somewhat a computer geek and I can tell you a router is NEEDED. It offers a layer of security the software firewalls cannot. It will hide connected computers from other computer (with bad dudes working on them).
    Routers are cheap, please do not use your networked (wireless or wired) computer without a router. While they will not stop everything you computer is much better protected than without.
    I hope this helps.
    Kevin
