Livin Lite Quicksilver 8.1 3" Lift and 14" Tires
Discussion in 'Tires / Brakes / Bearings / Axles' started by vulcan classic, Aug 27, 2013.
  1. vulcan classic
    vulcan classic New Member
    84
    Jan 21, 2013
    So I am in the process of adding a lift to my LL/QS camper; I will be adding 14" wheels and all-terrain tires. My goal is to be able to take it off-road and add a little more ground clearance and to raise it up level with my lifted Jeep Wrangler.
    I have installed 2" x 3" x 12" long 0.25" T6 6061 aluminum rectangular tubing in between the axle mounting brackets and the frame mounting brackets using 1/2" Grade 8 hardware, $64 shipped from McMaster Carr.
    http://www.mcmaster.com/#6546k281/=o8hii0
    I purchased a pair of 14" x 6" steel trailer wheels, 5 on 4.5, with 0 offset, $76 shipped from Recstuff.com.
    http://recstuff.com/14X6-5-4.5-Silver-Spoke-Trailer-Wheel.aspx
    I purchased a pair of BFG AT/KO's, LT195/75-14, $256 shipped from Discounted Wheel Warehouse.
    http://www.discountedwheelwarehouse.com/BF_Goodrich_All_Terrain_T_A_KO_Tires.cfm?pn=BFG%2D34557&pID=188
    I'll post up pics once all the work is completed. I also plan on removing the PVC bed bunk poles storage tube under the frame for added ground clearance. In addition, I will modify the stabilizer jacks on the corners by adding 3" stand-offs at each and under the entry step if needed.
  2. kmh1596
    kmh1596 Wilbraham, MA
    5,362
    Aug 20, 2007
    Western MA
    Sounds like fun. In progress pictures are always great, too! [RTM]
  3. vulcan classic
    84
    Jan 21, 2013
    Re: Livin Lite Quicksilver 8.1 3" Lift and 14" Tires
    Here's the finished project...
    Stock 12" wheels and tires
    3" lift with 14" wheels and 195/75-14 BFG AT KO's
  4. Idaho
    Idaho New Member
    Mar 16, 2016
    We added a 3" lift to our 2013 Quicksilver 8.0, but there is not enough room in the wheel wells for wider tires. How did you get your larger tires to fit?
