Load star vs Carlisle 6 ply?
Discussion in 'General Camping Discussion Forum' started by MichaelC, Jul 3, 2015.
  1. MichaelC
    MichaelC New Member
    Jul 1, 2015
    Looking to replace tires on my newly acquired 2002 viking epic 1706. Suggestions? It has 4 pugs. Class B or C? Carlisle or load star....or any other suggestions. Thx!
  2. MichaelC
    MichaelC New Member
    Jul 1, 2015
    Lugs, not pugs....lol
  3. MichaelC
    MichaelC New Member
    Jul 1, 2015
    4.80-12 is what is on there now. What about Kenda brand? Is that load star?
  4. mv520
    mv520 Member
    587
    24
    May 2, 2010
    Yes, Kenda makes Loadstar
  5. xxxapache
    2,991
    980
    I had Loadstar on my Apache for 8 years. I never had any problems.
    kcsa75 likes this.
  6. MichaelC
    MichaelC New Member
    Jul 1, 2015
    Thank you mv and xxxapache!
  7. AlsChopShop
    AlsChopShop Delightfully Incompetent
    94
    Jul 21, 2014
    Make sure the weight rating of the tires exceeds the weight of your pup. That's the most important thing.
    Al
    Sent from my HTC6500LVW using Tapatalk
  8. travisma
    travisma New Member
    217
    Jan 10, 2014
    And the higher rating needs higher pressure for inflating. So make sure your compressor and tire gauge can handle those pressures.
    I had to purchase a new tire gauge when I went from 2 ply to 6 ply tires.
  9. kitphantom
    11,948
    1,006
    We had good luck with the Kenda Loadstars on our pup, and ordered them from etrailer when no one in town seemed to be willing or able to order them. They came as standard on the TT, so we plan to buy them again when it's time to replace those tires.
    And yes, we had to buy a new tire gauge for the camper tires.
  10. niagarafam
    niagarafam Active Member
    2,157
    Jan 25, 2014
    Go with the higher load rating; overkill on tires is a good thing. The factory put underrated C range bias on our heavy Niagara. After a wear problem fiasco, we put D rated radials on it. So far so good. Call etrailer; they will set you up right.
  11. MichaelC
    MichaelC New Member
    Jul 1, 2015
    Thank you all for your input! Went with Kendas from etrailer. 6 ply. Great price, only 62$ each with galvanized rim and free shipping. Will def be doing biz again with etrailer.com
  12. SpaceGuy85
    SpaceGuy85 New Member
    May 1, 2019
    League City Texas
    20200105_171833.jpg 20200105_154343.jpg 20200105_154326.jpg Guys, my experience with the Kenda's is horrible. Blowout after only 250 miles. I think that the dealer is going to put carlisle tires on it under my warranty, and, fixing the side of the camper that was damaged by the China Bomb. Not sure why, but, they told me that Forest River is now using them instead of the Kenda's. Not sure it really matters, as they are both China Bombs anyway... We need to go back to american made tires... View attachment 58398 View attachment 58398 View attachment 58399
    bheff likes this.
  13. xxxapache
    2,991
    980
    What bent the rim?....Looks like a pothole or debris bent the rim and caused rapid air loss, then the tire came apart from heat.
    kcsa75 likes this.
  14. bheff
    bheff Well-Known Member
    1,184
    628
    Feb 24, 2011
    NW Arkansas
    kcsa75 likes this.
  15. joet
    4,885
    1,013
    X2
  16. SpaceGuy85
    May 1, 2019
    League City Texas
    Nope, the bent rim happened when the tread came off, and after the loud blowout. I have the video of it happening, (which we turned over to our attorney) that shows that we never hit anything at all. But, thanks for that thought. I did think the same thing until we saw the video. Kenda tells me I was overloaded, but, my max is 3566 according to my labels on the camper. My weight at the cat scales for the camper was 2245, so that was not it. I really think it probably is the fact that the tires were from 2015, and therefore could be just old. Again, thanks for the input.
  17. tombiasi
    5,530
    1,194
    I have an Epic 1906
    It came with 480 x 12 LR B I now use 5.30 x 12 LR C
    I have had two defective tires from Kenda. I prefer Carlisle but they are a little harder to find. I still will use Loadstar, anything can be defective and they sent me new tires.
  18. davekro
    davekro Active Member
    581
    171
    Aug 30, 2019
    SF Bay Area, CA
    My tires are 6.5 years old & spare is 1999, so I'm upgrading to load range D. My pup's GVWR is 2200lbs (same as the axle) even though the 5.30-12 Carlisle tires combined capacity was about 2100 lbs. My new tires will add 350 lb capacity for the tires. I want the tires NOT to be the weak link... this may help.
    I also wanted to spruce up from the white steel wheels, so I'm going with the HWT Aluminum rims/ Kenda tires combo from Etrailer. (3) tires.
    Kenda KR25 Radial Trailer Tire with 12" Aluminum HWT Wheel - 4 on 4 - Load Range D
    Item # AM31208HWT
    bheff likes this.
