Looking for portable solar sun tracker
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by rmihalcin, Oct 14, 2021.
  1. rmihalcin
    rmihalcin New Member
    Jul 30, 2013
    Looking for portable solar sun tracker like the attached photo. I grabbed this photo from the internet and I can't remember where I found the photo. It's a pretty slick gadget for pointing your portable solar panels towards the sun. Has anyone ever seen this commercially available?
  2. Hilldweller
    Hilldweller Well-Known Member
    686
    1,173
    Mar 2, 2021
    Hog Waller, GA
  3. Sjm9911
    10,776
    8,151
    Looks prety simple to make also.
  4. Anthony Hitchings
    3,160
    1,881
    Mar 2, 2019
    Oakland, California
    the pic shows an aiming device, not a tracker
  5. Anthony Hitchings
    3,160
    1,881
    Mar 2, 2019
    Oakland, California
    that aimer is not necessary, the sun is constantly moving. U can use a panels shadow as a guide, less shadow means a more direct aim at the sun
  6. WrkrBee
    WrkrBee Un-Supported Member
    6,569
    3,461
    Yep. They sell PVC pipe fittings every day. Stick a PVC coupling on the side of the panel. Adjust panel until there is a circle on the ground and the panel is aimed directly at the sun.
    SHFL and Eric Webber like this.
  7. Econ
    Econ Well-Known Member
    1,496
    921
    Aug 18, 2019
    Deep South
    i'm a dumb hic from the South. We wouldnt know how to invent something fancy like that. We would just get a cardboard tube from a roll of toilet paper and hold up to the panel. If it is pointing dead at the sun the shadow inside the tube would be equidistant. Adjust as needed. The used ones are still free. <GG>
    SHFL and Anthony Hitchings like this.
  8. BikeNFish
    BikeNFish Well-Known Member
    4,156
    3,139
    Apr 24, 2017
    Maplewood, MN
    I do something similar except I use a pop can or water bottle against the solar panel. When there is no shadow, I know it is centered. But in reality, solar panels only stay centered for a short time. As long as the earth keeps turning, you'll always be chasing the sun! [SUN]
    SHFL, Econ and Sjm9911 like this.
  9. Econ
    1,496
    921
    Aug 18, 2019
    Deep South
    My solar panel trickle charges the battery and is located on a major pathway thru the yard. The camper is passed frequently so I sneak a peak at the monitor. The degradation of output from not being pointed directly at the sun is questioned. I dont bother adjusting it anymore as it is not worth the effort. Maybe twice a day.
  10. rabird
    7,775
    860
    N. TX
  11. Tarkus
    Tarkus Member
    82
    60
    Aug 15, 2021
    Wyoming
  12. Eric Webber
    Eric Webber Well-Known Member Gold Supporting Member
    697
    617
    Jul 7, 2018
    Montreal, Quebec, Canada
    I tilt to about the same angle as latitude and don't worry about facing the sun, just focus on being somewhere in the path without too many obstacles.
    At home, I had very few good angles, so I just over-panelled. The ones seeing sun at 9am are not the ones seeing sun by 2pm. But, panels are cheap (compared to charge controllers and batteries at least
    Tarkus likes this.
  13. chiques
    chiques New Member
    Oct 4, 2020
    This is a starting point.
    Ken Kroeger likes this.
  14. gladecreekwy
    1,559
    2,403
    Sep 25, 2016
    Jackson Wyoming
    We move ours three or four times per day. It’s generating power regardless if it’s pointed directly at the sun. I don’t worry too much about it.
  15. rmihalcin
    Jul 30, 2013
    Thank you all for the great suggestions. I think I'll tilt the panels at the camping latitude. The gadget doesn't seem to be available any more.
