Loud noise
Discussion in 'Tires / Brakes / Bearings / Axles' started by nedchiu, Jul 25, 2007.
  1. nedchiu
    nedchiu New Member
    Mar 6, 2007
    When I apply the brake a loud "cluck" noise occurs. It seems like the brakes are hitting really hard. If I use the hand controller there is no noise. Are the brakes engaging to hard. I have tried to adjust the hard and soft setting, but the noise is still there.
    Thanks,
  2. jhower
    jhower New Member
    1,208
    Jul 25, 2006
    The brakes may need adjustment. There will be a noise when the magnets engage, and if the brake shoes are too far from the drum that may be the cause of the noise you hear.
    Are the brakes working OK, other than the noise?
    John & Cindy in Pennsylvania
    <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle> 2007 Flagstaff 620ST purchased 05/07
    <img src=../Images/icons/icon_smile_hardhat.gif border=0 align=middle> Mods started 5/07!
    '89 Coleman Sun Valley, sold, and now in Louisiana
    <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle> '95 Dodge Dakota 4x2 3.9L
    Nights camped in 2007: 10
  3. nedchiu
    nedchiu New Member
    Mar 6, 2007
    Yes the brakes are working fine. It does sounds like the brake magnets are engaging. I just repacked the bearings and looked/grease the brakes. How do you adjust the brakes?
    Thanks,
  4. jhower
    jhower New Member
    1,208
    Jul 25, 2006
    There is an oblong plastic plug on the rear of the backing plate. Pull that plug and use a screwdriver to engage the star wheel inside the drum. You'll need to have the PUP jacked up and properly supported so you can spin the tire with your hand while turning the star wheel. Turn it until the tire has resistance then back off until you feel just a little resistance when spinning the wheel. Replace the plug to keep water out of the brakes.
