Making an opened camper less bouncy?
Discussion in 'Stabilizing Your Camper' started by raindog308, May 9, 2015.
  1. raindog308
    raindog308 New Member
    33
    Mar 3, 2015
    Just came back from our first trip in a new-to-us 1982 Coleman Sun Valley. Great time but one thing we noticed is that the camper was very bouncy.
    Whenever one of us would change sleeping positions, or our dog would pant on the floor, etc. the whole camper would rock.
    This is the first popup I've owned so maybe that's completely normal...and it's really not a big deal. Maybe we just need to go on a diet [LOL]
    Just wondering if this is normal/to be expected or if there is some trick to minimizing bounce?
  2. clydee
    clydee Member
    70
    Dec 9, 2014
    I have 3 kids, wife, and a dog.
    no risky business the wife says, its too bouncy. :(
    I fixed it (on my camper) wife says still no risky business WHATEVER!!!
    First, I purchased extra wheel chocks, so I chock BOTH wheels. one will rock even one side is "locked" in,so I chock both.
    it helped but...
    I put 4 stabilizer jacks (http://www.amazon.com/Camco-44560-Olympian-Aluminum-Stack/dp/B000760FWU/ref=sr_1_sc_1?s=automotive&ie=UTF8&qid=1431229713&sr=1-1-spell&keywords=camper+stablizer+alumium)
    a world of difference in bouncy, but it still has slight slight bounce, or whatever we call it - but its MAJORLY better, when the wife moves while sleeping on other end, it didn't wake me up like last time.
    but again, new memory foam mattresses really helped the sleep too..
  3. speckhunter80
    4,782
    63
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    Chock both wheels front and back....lower stabs so they are snug
  4. mcbrew
    mcbrew Member
    774
    May 22, 2013
    I use a Valterra RV Stabilizer. It does not mount permanently -- you just put it in place when you set up camp.
    My little PUP doesn't have front stabilizers, so it is especially "rocky" when moving around on the front bed. This has completely solved that problem.
  5. 3hooligans
    3hooligans Member
    622
    Jul 27, 2014
    Boston
    I put all ofr stabilizers down, and chock both wheels front and back and sinch them together with a ratcheting strap.
  6. kitphantom
    12,151
    1,172
    Well-chocked and stabilized (4 stabilizers) helps immensely, but we always notice some transferred vibrations - footfalls, rolling over, standing or sitting.
    We realized that, for us, part of it is the fact that we live in a house on a slab foundation. I notice movement in houses and buildings that are built on cellars or crawl spaces more than I used to.
    Our first pup did not have a full set of useable stabilizers when we first used it, and we really noticed movements. Once we renovated it and were able to use all 4 (stack-jack) stabilizers, things were better. Repairing a portion of a side wall so that it was re-attached to the floor helped some of the flex when someone was at the outer edge of the bunk, but that is less likely, unless you have an older camper.
    We also noticed movement in the second pup, but less so - built-in stabilizers, and tires that were better to chock. [The first pup was tiny, so jamming a chock under the tire was interesting, second pup much better, and we learned to use a rubber hammer as needed to firm up the chock.] Now with the TT, movement is still less, but I do notice vibrations as we walk around.
    BTW, if you add the make, model and year of your pup to your signature line (through the "forum profile" section), it helps the rest of us.
  7. jrclocks
    jrclocks Member
    585
    Jun 24, 2008
    Here are the things that helped our Sun Valley...
    When chocking the high wheel, back up onto the rear chock and hold the brake while DW puts the front chock in place. Let off the brake and the camper settles into the chocks. This really secures the high wheel. You'll have to reverse the process to remove the chocks when packing up.
    Use a BAL leveler on the low wheel.
    Just using the stabilizers isn't enough because they can still "wiggle" side to side. I installed a telescoping corner brace on the front stabs. It helped immensely!
    JR
    Mamie likes this.
  8. vinmaker
    vinmaker Member
    862
    Aug 22, 2014
    That is a great idea. I like that.
    Were the braces home made? You have a link?
    Vin.
  9. raindog308
    33
    Mar 3, 2015
    Wow, thanks for all the helpful advice!
    We chocked though didn't really hammer them in...will do next time. We do get the stab jacks in solid. In this case, we were on pavement.
    I suspect some of it is just newbies getting used to the trailer but we will definitely check out some of the advice here. Thanks again.
  10. E3 Junkie
    E3 Junkie Greetings from Granada Hills, CA.
    314
    Sep 22, 2012
    I added a BAL 94-1214 to the center section of my E3, and it made all the difference in the world. The frame no longer flexes.
  11. tigerflier
    tigerflier Member
    219
    Mar 18, 2015
    I don't think anyone mentioned this but if your tire pressure is low it will allow much more bounce in the pup
  12. Bowman3d
    Bowman3d Well-Known Member
    855
    363
    Apr 13, 2015
    LaLa land (SoCal)
    I'm thinking of adding a stabilizer just in front of and just behind each tire. The wife gets up every 2 hrs to use the backroom. We bounce a lot.
  13. mcbrew
    mcbrew Member
    774
    May 22, 2013
    Seriously, try the Valterra... No installation to the pup, and you can move it around to find the proper location. It is lightweight aluminum and folds down to about the size of a small folding chair.
    Somewhere I had a pic of it set up under my pup, but I can't find it now.
    Because it is trapezoidal, it helps to brace against movement.
  14. Bowman3d
    855
    363
    Apr 13, 2015
    LaLa land (SoCal)
    McBrew I saw the pic of it posted earlier in this thread and I am thinking of using those. I think they would be perfect for what I want
  15. turborich
    turborich Active Member
    1,908
    Jun 22, 2010
    Las Vegas, NV.
    This is all it takes. It works for me, my pup is pretty darn solid.
  16. f5moab
    1,421
    469
    May 7, 2013
    Somewhere in Idaho
    Basically the same, except I have a BAL leveler on one side which is just like a wheel chock. No problems, even with 2-100 lbs dogs running back and forth.
  17. SmilinBeard
    SmilinBeard Member
    507
    Feb 18, 2008
    My stabilizers have the sand feet on the ends which helps stabilization some, but I found if they were fully extended [as in the back legs are down a slope] they wobble. To void extending them down so far I put a couple Linx levelers under them and it helps a lot .
    Also, if the ground is loose gravel, or soft, they sink in and get loose with time. I put Linx levelers, or small plywood squares under the sand feet to act as a snow shoe.
    All the time, I find there is a little settling that goes on. Before bed, a circle around the pup and make sure they are all snug. Rarely, I have to go around a second time the next morning or evening. After that, it is rock solid.
  18. Rusty2192
    Rusty2192 Well-Known Member
    993
    426
    Jul 30, 2014
    Kentucky
    I use a set of 4 of those with my pup and they do work great, just a little time and space consuming vs other options, namely screw down jacks. I've only had to put boards under my stabs when they weren't tall enough due to an unlevel site. And there isn't any worry about going through the floor since they should just be snug against the frame, not holding anything up. The wheels and tongue Jack hold everything at the proper level.
  19. tombiasi
    5,815
    1,392
    Chocks and stabs are fine but when someone moves in one bunk the canvas will transfer the movement to the other bunk.
  20. owenpsmith
    owenpsmith New Member
    18
    May 27, 2014
    I chock with 2x4s, front and back on each wheel. Once trailer is positioned, I pull forward and inch or two to get the tires to ride up on the front chocks a bit, then get the DW to kick the rear chocks in tight. I find this decreased wiggle quite a bit compared to just kicking the chocks in after positioning.
    Also, ensure you are using a stand for your tongue jack instead of the wheel.
