manual crank won't crank
Discussion in 'Lift Systems' started by Ntk37, Aug 24, 2019.
  1. Ntk37
    Ntk37 Member
    37
    25
    Jun 7, 2019
    My Rockwood 2516G (2007) wont crank manually. Batteries are dead, power hasn't juiced them up yet so we tried to use both the crank then the socket. Gave up after a minute or so because we saw NO signs of movement. Does it just take a really long time to get going? Or is it broken? It's always popped up fine when plugged in. It was taken down yesterday at the shop with a drill bc the battery was so dead.
  2. tombiasi
    5,371
    1,004
    You need to access the mechanism and see what's happening. It will be hard for anyone to help with that little info.
    Perhaps a picture.
  3. bheff
    bheff Well-Known Member
    955
    465
    Feb 24, 2011
    NW Arkansas
    Some say it will take 20-30 minutes to hand crank it
    neighbormike likes this.
  4. MintHillBill
    MintHillBill Member
    133
    Jun 11, 2008
    I believe it, the ratio is like 100 to 1.
