Manual raising when electric is not working
Discussion in 'Lift Systems' started by Chris4598, Oct 6, 2021.
  1. Chris4598
    Chris4598 New Member
    Aug 6, 2021
    Florida
    My pop-up’s electric wench is not working, but when I tried to raise it manually it failed to engage the cable. It is a 2015 Rockwood Freedom. Please help
  2. PopUpSteve
    PopUpSteve Administrator
    20,010
    2,932
    Dec 22, 2002
    Malvern, PA
    Not sure which electric wench you have but mine must have the power must be disconnected from the electric wench before using the manual crank.
  3. Chris4598
    Aug 6, 2021
    Florida
    It was after market add on I believe. Is there a way you disconnect the power other than disconnect the battery? When I cranked the gears were moving but the cable did nothing engage.
  4. PopUpSteve
    20,010
    2,932
    Dec 22, 2002
    Malvern, PA
    Mine has a disconnect right at the electric wench.
  5. Chris4598
    Aug 6, 2021
    Florida
    Thanks/I will look for that in th ER morning.
  6. Chris4598
    Aug 6, 2021
    Florida
    Unfortunately I see no cut off for the wench…any other ideas?
  7. Chris4598
    Aug 6, 2021
    Florida
    Please see the pictures below for the electric wench. Looking for a way to get my Popup up without electricity
  8. Grandpa Don
    Grandpa Don Well-Known Member
    1,417
    1,065
    Sep 5, 2018
    Southern California
    Can you just remove the winch entirely and install a manual winch. A Cordless 1/2 inch drill would work much better for raising and lowering.
  9. Chris4598
    Aug 6, 2021
    Florida
    Would we have to change the whole wench or just remove the motor and all?
  10. Grandpa Don
    1,417
    1,065
    Sep 5, 2018
    Southern California
    I might be missing something here, but most people who convert to a manual do remove the motor and the whole winch frame. There are only three bolts holding it on to the tongue. A manual winch is a direct bolt on configuration. Same bolt pattern. Bolt it to the frame, attach the cable and start cranking. What am I missing?
  11. Chris4598
    Aug 6, 2021
    Florida
    If I remove what is there, as far as the electric winch goes, would the cable get unwound and have to be rewound around a new spool? Or would it stay on the spool it is on?
  12. WrkrBee
    WrkrBee Un-Supported Member
    6,539
    3,448
    Cable is removed from old winch and installed on new winch drum.
  13. Annunzi
    Annunzi Active Member
    175
    149
    Jun 14, 2019
    Vancouver Island, British Columbia
    I just replaced my power winch with a manual one. I had to cut the cable because of the way it was crimped onto the power winch. It was tricky to cut because I didn't want to lose much length, so I rough cut it with my oscillating tool, then cleaned up the end with the cutoff saw.
  14. Chris4598
    Aug 6, 2021
    Florida
    Yikes! That sounds scary. Removing the cable from one spindle to another is something we want to avoid-don’t want to chance having to read-cable the whole thing. A new switch is coming today and in the mean time working on raising it manually.
