math help
Discussion in 'General Camping Discussion Forum' started by p, Feb 17, 2020.
  1. p
    p Active Member
    576
    150
    Jun 9, 2014
    The details:
    -20,000 btu propane bbq
    -connected to lp of tent trailer (ie. 20 lb propane tank)
    Question- How many pounds per hour do i use up with the bbq?
    (Yes, I know it will be a decimal)
    Does 0.433 lb make sense ?
  2. tombiasi
    6,008
    1,527
    It will be what ever the unit uses. We need the specs of gas consumption. They are not all the same.
  3. p
    p Active Member
    576
    150
    Jun 9, 2014
    It is a coleman roadtrip. I want to have an estimate so that i ensure i will not run out and not have a furnace.
  4. tombiasi
    6,008
    1,527
    Well, I don't have time to look up the specs for you. If you can provide them I will help.
  5. Sjm9911
    7,368
    4,751
    Yea , kind of agree it depends on what the output is. So if the burners are both on high, or low. Why are you running it for hours anyway? Lol. My home propane tank lasts a while and i use it a lot. If camping i run the 20 lbs out quicker if i use the propane fire pit. Those can use up propance as tou so have them on for hours. A BBQ grill just cooking will probably last way longer then your camping time.
  6. Sjm9911
    7,368
    4,751
    Oh , so your running what? And want to k ow how long a tank can last?
  7. generok
    generok Well-Known Member
    2,845
    1,177
    Feb 7, 2013
    Anchorage, AK
    A pound of LP contains 21,500 BTU. If your grill is operating at 20,000 BTU, you are burning just shy of 1 pound of LP per hour of run time. YMMV.
    BelchFire likes this.
  8. lksdrinker
    lksdrinker Active Member
    210
    54
    Oct 15, 2018
    Keep in mind that many "20 lb propane tanks" are only filled to about 15 lbs. Or so I've been told thats the way most places that swap tanks (as opposed to filling right there for you) do it.
  9. p
    p Active Member
    576
    150
    Jun 9, 2014
    Perfect...thanks for the response. I wanted to make sure I do not run out of propane for the furnace.
  10. Sjm9911
    7,368
    4,751
    The furnace will eat up the propane, especially in cold weather.
  11. tombiasi
    6,008
    1,527
    If you are on battery, the battery won't last as long as the propane.
    theseus and Sjm9911 like this.
  12. RockyRoo
    6,591
    223
    Jun 8, 2012
    My suggestion, if you can, take an extra tank with you. 1 for the trailer and 1 for the grill. Worst case scenerio if the furnace tank runs dry in the middle of the night you can swap the grill tank into service and stay warm
  13. MileHigh
    MileHigh Active Member
    472
    72
    Jul 18, 2012
    Denver
    The propane grill if ran on high would last just over 21 hours if it was really 20 pounds of propane. Tanks are considered full though at 80% which reduces the time to 17 hours.
    A gallon of propane gives 91,500 BTU's and weighs 4.23 pounds.
  14. Econ
    Econ Well-Known Member
    796
    392
    Aug 18, 2019
    Deep South
    There are may variables to tank fullness. There is the persistent story that exchange tanks only have 15 pounds in them. Our two oldest bottles are on the camper. We only exchange bottles when both are out while on a trip, hasn't happened yet, or the certification is expiring. One local filling station will only fill to 16 pounds. There is written info at the Uhaul filling station that they fill to 19.4 pounds. That's a 36 pound target minus the tare.
    Edit,,,, The above was written before 6:51AM which is before my 9 am brain fully engaged time.<GG> The correct info written on the UHual sheet is the target is 4.5 gallons times 4.2 pounds equals 18.9 total pounds plus tare of 16.6= 35.5 pounds. Since its before 6 am right now I will go back to sleep
    FARfetched likes this.
  15. scubacamper
    scubacamper Well-Known Member
    1,343
    185
    Mar 19, 2013
    Jacksonville, FL
    Here's a different thought on the subject as propane is heavy to carry. If you are boondocking then this won't help but if you have power access, buy a small electric heater, we did for less than $30 at Walmart and it heated the PUP nicely within minutes saving our gas for the stove and other things. Just an alternative.
    Melissa Freeman likes this.
  16. Melissa Freeman
    Melissa Freeman New Member
    Nov 5, 2019
    Indiana
    That's what we did and it worked out great.
  17. Anthony Hitchings
    1,547
    802
    Mar 2, 2019
    If you are propane hogs just plan on refilling it part way thru your trip. We did 3 weeks in Yellowstone area and only used part of our tank, then did a thanksgiving trip on the same tank. It was a 15 Lb exchange tank. We did use the heater in the mornings.
  18. ST Dog
    ST Dog Member
    91
    Feb 18, 2017
    Rocket City, USA
    Blue Rhino states it in their FAQ. Starting in 2008 they dropped from 17lbs to 15lbs. (Same price, less propane instead of increasing price)
    https://bluerhino.com/propane-info/faqs/buying-blue-rhino-tanks-faqs
    (Bad enough they were only filling to 17lbs, but now only 3/4 full.)
    Supposedly it's also marked on the package and other signage.
    I never use nor even look to verify.
    I just checked Home Depot online and their exchange tanks (AmeriGas) say 15lbs net weight on the label.
  19. bheff
    bheff Well-Known Member
    1,504
    920
    Feb 24, 2011
    NW Arkansas
    I'm fortunate. On Fridays the local propane place fills the 20 pounds tanks for $5.
    BBQdave likes this.
  20. ST Dog
    ST Dog Member
    91
    Feb 18, 2017
    Rocket City, USA
    Wouldn't go back there. Only using 3/4 the capacity.
    Better but still stopping 1lb short of where it should be.
    The tanks are sized to hold 20lb and still have the required headspace for expansion.
