Mattress and sheets
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by Maranda Peterson, Jun 27, 2020.
  1. Maranda Peterson
    Maranda Peterson New Member
    Jun 27, 2020
    Oregon
    What is the best fitting sheets and foam topper you are using? I herd Jersey Sheets work best as they are stretchy. I also read someone took a King sized foam topper and traced the old pad and cut down to size??
  2. jmkay1
    5,629
    2,429
    Don't know about foam topper as I don't use one myself. I use jersey sheets in a size down from the mattress size and they work great. However they can be quite warm to sleep in especially in the summer and if they got wet for whatever reason take forever to dry. Some also just bought a larger size top sheet and just tuck in the excess or use those sheet clips to help hold them in place some. Then a smaller size top sheet to use.
    Maranda Peterson likes this.
  3. Maranda Peterson
    Jun 27, 2020
    Oregon
    Thank you, I'm in Oregon so even on hot summer nights it gets cold in the mountains so those will be perfect. Defiantly will get that forever dry. thanks for the help!
