Max Rise Safety Concerns?
nwcurt
Sep 23, 2017
27
Good morning,
I flipped the axle on my '05 Fleetwood Tucson and need a pretty significant rise on the hitch to tow it level.
I know they sell the hitches as "drop -OR- rise", but are there any safety concerns using a hitch that's at a 10" or even 12" rise? It looks a little funny - especially since it seems almost all hitch setups are with a DROP, not a RISE at all.
Just making sure I'm not risking some kind of colossal towing failure. Any advice or input is appreciated.
Thanks!
WVhillbilly
841
WV
I had a 6 inch (ish) drop hitch that I used with the big pick up and motorcycle trailer.
Truck is gone, 4Runner is shorter, pop up is taller.
Flipped the ball on it and have used it a couple years now with no issue.
What are you towing with that you'll need that much rise and why did you lift the camper so high?
Because 10-12" is a LOT of difference.
I don't think that using it flipped over is a safety or strength issue, you're only towing a light pop up.
nwcurt
Sep 23, 2017
27
I lifted it so I could put some real tires on it and get some more clearance on bad forest service roads. We had an almost identical popup a decade ago and went through 4 tires on a month long road trip. Wanted real radials this time. It raised it about 4".
The tow vehicle just happens to have a low-sitting hitch. It actually has a pretty high bumper and clearance itself ('08 Kia Sorento), but the hitch mounts pretty low.
Thanks for the input!
WVhillbilly
841
WV
This is why I bought a tall camper to start with.
I look at older ones and can't understand how they don't drag everywhere.
generok
3,472
Anchorage, AK
Yeah, there's no need to worry about using a drop/rise mount in the rise configuration... it's designed to be used that way (unless there are specific restrictions from the manufacturer, of course).
MNTCamper
1,359
MN
I use a 5" lift on my minivan - always have. No issue at all. higher lift requires a bit more reinforcement of the receiver insert, but will tow just fine.
Rusty2192
1,198
Kentucky
Just check the weight capacity of the ball mount. It isn’t too common, but I have seen some with different capacities for drop vs rise. I doubt it will be an issue with a pup, but I’d check just to be sure.
Latest posts
