maximum roof screw length
Discussion in 'Miscellaneous Repairs & Maintenance' started by Fred1diver, Sep 11, 2019.
  1. Fred1diver
    Fred1diver Active Member
    214
    110
    Sep 11, 2018
    hey everyone my bunk end rail system is coming undone (screws coming out) what is the maximum screw length I can use since it screws on the roof. next year I might have to redo the ceiling, the pup is 20 years old after all.
  2. WrkrBee
    WrkrBee Well-Known Member
    2,582
    991
    Picture would help. What length are the screws that are coming out? What are the screws screwed into- wood or wanna be wood?
  3. Fred1diver
    214
    110
    Sep 11, 2018
    not sure what they are screwed in, could be wood could be foam, I'll take one out (I screwed them back in but they barely hold) and measure it
  4. Raycfe
    15,390
    1,569
    I would epoxy the holes and use the same length screws ....... nothing longer
  5. WrkrBee
    2,582
    991
    Hopefully, in 1999 they were still using real wood, not particle board or MDF board. Try a good wood glue and wood toothpicks or wood matchsticks to fill the hole. Put glue on each one and insert it in the hole. Continue until the hole is full. Let dry and reinstall the screw.
  6. Fred1diver
    214
    110
    Sep 11, 2018
    thanks everyone, you all gave me some good ideas on how to fix it
  7. Fred1diver
    214
    110
    Sep 11, 2018
    ok so I took one off and they are ⅝ screws, I'll go get some wooden toothpick and fix it up before the end of the season as I have 2 camping trips planned
  8. Fred1diver
    214
    110
    Sep 11, 2018
    ok so I decided to forgo the toothpick repair and go with epoxying the holes, have all that I need at home (don't have wood glue or toothpicks lol)
    I'll make a batch of epoxy and use syringes to fill the holes.
  9. bheff
    bheff Well-Known Member
    952
    462
    Feb 24, 2011
    NW Arkansas
    Sometimes filling holes with epoxy on a vertical surface is tricky. The epoxy wants to ooze out. You can use clear packing tape to cover the hole. Epoxy wont stick to it.
  10. Fred1diver
    214
    110
    Sep 11, 2018
    so I ended up doing both the toothpick and epoxy, it works great, problem solved
