Maybe a dumb question regarding cold weather use...
Discussion in 'First Time & New Camper Owners' started by RVAcampcouple, Mar 21, 2018.
  1. RVAcampcouple
    RVAcampcouple New Member
    21
    Mar 9, 2018
    Richmond, VA
    Forgive me if this is a dumb question, and I think I know what the answer may be, but I can't seem to confirm it anywhere.
    Girlfriend and I just purchased our NTU Coleman Bayside a few weeks ago and jave a reservation this weekend to have our first close to home overnight test run. It was winterized by the previous owner and I've left it that way because although it was warm when we bought it, it's been cold ever since [:(]. It is supposed to dip below freezing the night we go so I would obviously like to be able to use the furnace, is there a way to do this without dewinterizing the whole system? I'm assuming not, but hoping I'm wrong.
    We do have a small ceramic heater, but I don't want to rely on it because A) it is just a small, inexpensive one and B) we do not have PUG's or any sort of heat retention yet.
    Any advice for the new pup owners would be greatly appreciated!
    On a brighter note, the one problem we found after bringing it home was that the fridge didn't work on AC power. However, after lots of time searching for similar issues had by others, $80 for a new 120v heating element, and 15 minutes of my time to swap it out, it all works!
  2. xxxapache
    2,881
    877
    You can run the furnace.
    The only thing you do not want to do is use the water system.
  3. RVAcampcouple
    21
    Mar 9, 2018
    Richmond, VA
    Oh that's great news! I lit it briefly to make sure it worked, but for some reason I thought I had read something about not running it without water in the system because it could damage the hot water tank.
    Thanks for clearing that up so quickly
  4. giadiep
    giadiep Active Member
    394
    166
    Sep 5, 2015
    Syracuse, NY
    Furnace and hot water tank are separate units, so ok to run furnace.
  5. Antipodes
    Antipodes Call me Paul
    772
    75
    Jan 28, 2015
    Christchurch, New Zealand
    Maybe you could post a picture of what you think the furnace is? Just to be sure we are on the same page. Don't want you going away and not actually having a furnace and then to cook the water tank!
    xxxapache likes this.
  6. RVAcampcouple
    21
    Mar 9, 2018
    Richmond, VA
  7. f5moab
    1,423
    468
    May 7, 2013
    Somewhere in Idaho
    Strange message I get trying to view the photos:
    PopUpPortal - Error
    You do not have permission to view media within this album.
    But it sounds to me you're trying to light the water tank and you need water or it can cause damage. But I can't be sure cause I am no longer allowed to see photos; I guess.:(
  8. RVAcampcouple
    21
    Mar 9, 2018
    Richmond, VA
  9. Fless
    Fless Active Member
    948
    196
    Aug 14, 2012
    Colorado
    Your water heater is separate from the forced air heating system. On the outside, close up the water heater door that is part of the front storage box. Don't light that water heater up until you have water in it. After you de-winterize.
    Your furnace igniter is inside the cabin (behind the louvered cover you circled), and your PuP is new enough to have electronic ignition. Turn on the propane at the tank (on the tongue), then light a stove burner to make sure gas is flowing. Turn off the burner. Then turn the heater thermostat on and set the temp to a high value. You should hear the thermostat click, and the furnace should hopefully fire up. The blower comes on first for 20 or 30 seconds, then you should hear the tick-tick-tick of the burner lighting up (whoosh!). After it warms up for 30 seconds or so you should get warm air blowing.
    Let us know how it goes.
    _
    Jorja, BelchFire and RVAcampcouple like this.
  10. Fless
    Fless Active Member
    948
    196
    Aug 14, 2012
    Colorado
    And I would recommend getting and using a portable Carbon Monoxide (CO) detector. They can be had for $20 or so.
    _
    Jorja likes this.
  11. neighbormike
    2,285
    1,670
    Oct 6, 2012
    WI
    What Fless said! Crank up that furnace and have a great time!
  12. jnc
    3,921
    1,169
    Oct 1, 2014
    South Central New Hampshire
    Fless has it right. Good Luck & Camp On
  13. Antipodes
    772
    75
    Jan 28, 2015
    Yep as everyone else has said. Good job we got on the right track.
    Nothing worse than having a cold trip away.
    You can just make out the furnace exhaust beside/infront of your slideout.
  14. kcsa75
    kcsa75 Well-Known Member
    2,953
    1,354
    Sep 9, 2013
    Kansas City
    You're going camping with your girlfriend and you're worried how you're going to keep warm at night? [:)C]
    jnc, myride and RVAcampcouple like this.
  15. jmkay1
    4,844
    1,715
    Welcome from a Northern Virginia and a fellow fleetwood owner. I have the sister to the Bayside.
    Something I want to add to help with heat retention, you can buy reflectix from a home improvement store. You can cut these and put in the Windows. You will have to take them out when folding the camper, but sure helps keep the heat in especially on the bunk ends. Or you can bring along a fleece blanket and string it up like an indoor tent.
  16. CamperChrissy
    CamperChrissy Well-Known Member
    577
    289
    Nov 25, 2016
    Chicago suburbs
    Welcome and congrats!
    One way to make your bed warmer and more comfortable is to add anti-fatigue foam floor tiles under the mattress. This made a huge difference in comfort for me and will add extra insulation underneath.
    Something to keep in mind is that the built-in heater runs on propane. We've found that we don't run ours because, well basically, we're cheap : ). Propane costs money and since we always camp at sites with electric, we just bring our electric heater and it works great.
    Jorja likes this.
  17. bols2Dawall
    bols2Dawall S.W. Ontario
    1,444
    147
    May 19, 2010
    Lasalle Ontario
    and running your furnace a lot will drain your battery fairly quickly . Use a ceramic heater and use your furnace to supplement (keep on low)
  18. tfischer
    tfischer Well-Known Member
    3,528
    1,031
    May 21, 2014
    Not sure how this comment makes much sense. If you have shore power, to run a ceramic heater, then you should also have unlimited power to run the furnace. If you don't have shore power, then you won't be able to run a ceramic heater.
  19. bols2Dawall
    1,444
    147
    May 19, 2010
    Lasalle Ontario
    LOL , you're right . not sure what the heck I was thinking there
  20. Fless
    Fless Active Member
    948
    196
    Aug 14, 2012
    Colorado
    I once borrowed my neighbor's ceramic heater that ran on a small bottle of propane and D-batteries. Not sure you can still get those, but it was a nice little unit.
    _
