Miserable failure of coals...
Discussion in 'Dutch Oven Cooking' started by dbhost, Jul 28, 2019.
  1. dbhost
    dbhost Well-Known Member
    814
    321
    Sep 19, 2018
    League City, Texas USA.
    I was getting in some practice with my do yesterday and had something odd happen.
    Doing the -3, +3 method on a batch of biscuits, my top coals burned out super fast and of course I didn't have more started...
    Note for reference, get more coals going when you put the food in...
    Sjm9911 and Dusty road like this.
  2. Dusty road
    Dusty road Active Member
    839
    121
    Feb 28, 2016
    Conneaut, Ohio
    Sounds like it was a little windy. The wind break on my Camp Chef table is lower than the top of the DO lid, so I wired old license plates together standing on end and that helps a lot.
  3. dbhost
    814
    321
    Sep 19, 2018
    Yes it was actually a bit windy. I think I know what I did wrong. I'm using a weber kettle and a pizza pan as an improvised DO table. I usually use it on the coal grate, this time I was on the cooking grate exposing the DO to the ambient winds....
    Dusty road likes this.
  4. dbhost
    814
    321
    Sep 19, 2018
    What's really strange about this whole thing and it's probably just where food has been in contact with the Dutch oven but the seasoning on the lower half is pitch black and slicker then Teflon. The upper half not so much it's getting there but there is a distinct 2 tone effect going on inside the Dutch oven.
  5. dbhost
    814
    321
    Sep 19, 2018
  6. neighbormike
    2,532
    2,022
    Oct 6, 2012
    WI
    I have the Dutch Oven Helper app on my phone - pretty nifty coal calculator!
    hayyward likes this.
  7. dbhost
    814
    321
    Sep 19, 2018
    I haven't even considered an app.
    It seems that there are a number of apps and several fairly reputable websites that are recommending a 3:1ratio so for example for 350゚ in my 12" oven they want 18 coals on top and 8 on the bottom. Which I get that's a 3 to 1 + 2 which means basically the additional 2 are supposed to push it to 350゚ instead of 325.
    I can't find the Dutch Oven Helper in the Google play store so I'm assuming it's probably something for IOS which I don't have. However there's a large selection of the chevon calculators for android
    neighbormike likes this.
  8. neighbormike
    2,532
    2,022
    Oct 6, 2012
    WI
    I tried to send a link to the app but not sure how.
  9. dbhost
    814
    321
    Sep 19, 2018
    How very strange...
  10. Sjm9911
    5,973
    3,425
    Wow, thats almost too much adding for me! Thats why i dont bake, too much dependent on exact temps.
    Rik Peery and neighbormike like this.
  11. neighbormike
    2,532
    2,022
    Oct 6, 2012
    WI
    Hence the "app" [:D] I don't do a lot of DO cooking, but it's a handy little tool when I do!
  12. dbhost
    814
    321
    Sep 19, 2018
    So I did some digging around, and that Dutch Oven Helper is an app for Apple, no Android version exists. However there are Dutch Oven temp apps out there...
    I am seeing in the charts a LOT of variation between methods for temp control, I have in the past used the +/-3 method with some success, but this weekend was the first time I did it not in a fire pit with a tall fire ring, OR in one of those tall campground grills where the grate swings away and makes a 3 sided wind break / fire table...
    I am also seeing the 3 to 1 method which is what Easy Dutch Oven Calculator. I have not tried that one, but with the +/- 3 method sometimes, more often than I care for, the top is undercooked... I might just have to try the 3 to 1 method and see how it works out.
  13. shelmily
    shelmily Well-Known Member
    3,440
    371
    Jun 7, 2012
    Northeast Pennsylvania
    Easy way to remember. Take the diameter of your oven and double it. That's how many coals it takes to get your oven to 325 degrees. Every two more coals raises the temp about 25 degrees. If you are baking, 2 thirds go on top, 1 third underneath. So if you have a 12" oven, you need 24 coals, 16 on top, 8 underneath. If you need higher temp, add the extra coals to the top. Very easy!
    Sjm9911, dbhost and neighbormike like this.
  14. SteveP
    SteveP Well-Known Member
    1,603
    459
    If you don't mind math, DO diameter times 2 = number of coals for 325f, supposedly 1/3 on bottom 2/3 on top for baking, 1/2 on bottom 1/2 on top for roasting, all on bottom for boiling or frying but I use 1/3-2/3 when roasting also, I usually add 4 coals to the top to get about 400. If you add coals to increase temp always add to the top. If the biscuits aren't done in 20 minutes I move the bottom coals to the top and give it another 5.
  15. neighbormike
    2,532
    2,022
    Oct 6, 2012
    WI
    Glad I have the app... by the time I am thinking about dinner at the campsite, my mathing ability is more than likely going to be, well, impaired :grin:
    Dusty road, Sjm9911 and Rik Peery like this.
  16. Sjm9911
    5,973
    3,425
    He's the expert!
  17. billbillbillbill
    billbillbillbill Active Member
    108
    35
    Sep 4, 2012
    SLC, UT
    I had never thought about using an app. Thanks for sharing.
    To never be out of coals, I usually light a few extra in the chimney and then when I have my initial coals on the ovens, throw a few new briquettes in to be lit from the extras. Throwing the 2nd batch in the chimney is really easy with lit ones at the bottom. If I don't end up needing to replace them, I can use the newer ones for heating the oven up for cleaning and oiling.
    dbhost likes this.
