Moved to the Dark Side
Discussion in 'Going to the DARK SIDE' started by Rvfd1401, Feb 12, 2020.
  1. Rvfd1401
    Rvfd1401 New Member
    Apr 20, 2019
    East Tennessee
    They claim, 13,200 towing capacity with 3270 payload.
  2. xxxapache
    2,987
    977
    I am not sure any F150 is rated that high. If it is, it is a stripped down 2wd regular cab HDPP truck.
    SRW Super Duties are only rated at 12500 and 15000 bumper pull if I remember correctly. The 3.73 truck is rated lower than the 4.30 truck.
    Your payload is on the yellow sticker in the drivers door.
  3. RollTide30
    RollTide30 Member
    215
    21
    Jan 30, 2017
    West Georgia
    My 2016 F150 is rated at 12500, but it does have the complete tow package and is the V6 with ecoboost with aluminum body, but it is also a 4door. Where as my parents F250 is only rated at 12500 also, but it is like 13 years older too.
  4. xxxapache
    2,987
    977
    Aluminum frame? No...Aluminum body? Yes
    What is your trucks payload rating per the yellow sticker inside the door?
  5. RollTide30
    RollTide30 Member
    215
    21
    Jan 30, 2017
    West Georgia
    Yeah I typed it wrong, it is an aluminum body. Payload for my truck is 3240
  6. xxxapache
    2,987
    977
    You must have a HDPP truck, because that's nearly double the payload for most crew F150s...HDPP trucks are kind of a rarity
  7. giadiep
    giadiep Active Member
    430
    192
    Sep 5, 2015
    Syracuse, NY
    That is an impressive number for a 1/2 ton!
  8. RollTide30
    RollTide30 Member
    215
    21
    Jan 30, 2017
    West Georgia
    Its not a HD, but here is the numbers straight off the brochure and then confirmed on the truck:
    3.5L ECOBOOST For maximum capability, this direct-injection, twin-turbocharged V6 delivers 90% of its peak torque at 1,700 rpm – which holds on strong up to 5,000 rpm. 3,240 lbs. – Max. payload capacity
  9. RollTide30
    RollTide30 Member
    215
    21
    Jan 30, 2017
    West Georgia
    Now with that said, I'm not going to push it that far just as I don't want to be towing 12k either.
  10. xxxapache
    2,987
    977
    What the brochure says is max. Not all trucks are the same payload. Very few are rated at max.
    What does the yellow sticker inside your drivers door say? That is the payload for your truck.
  11. Sjm9911
    5,278
    2,881
    Ok , so i have to ask about the payload, thats whats in the truck right? You add the toung weight also? My GMC is about the same i think 3000. Its just a 4 door 1500 pick up. Tow rating are high also, because it has the max tow package and better gearing. I still would not be convertible towing a lot of weight as the TT now at 5500 or so max is a lot.
  12. xxxapache
    2,987
    977
    Yes, payload is cargo, passengers, tongue weight, and anything added to the truck after it leaves the factory.
