Moving by hand / trailer jack wheel
Discussion in 'Camper Storage / Winterizing & De-Winterizing' started by Spaceace5150, Jul 24, 2020.
  1. Spaceace5150
    Spaceace5150 Active Member
    184
    38
    Oct 1, 2014
    I have a driveway that is difficult to push the pop-up with the hard plastic wheel on the trailer jack. Has anyone seen any inflatable or rubber wheels that could be used for this? My driveway has some unlevel areas and its hard to push.
    It can be hard to turn the wheel to change directions and to go over cracks and bumps.
    Just wondering what others are doing? I searched for some threads on this but didn't see anything too recent.
    Thanks!
  2. Sjm9911
    7,407
    4,784
    Some get a trailer dolly. Other replace the wheels on the jack. Up to you.
    Blackripley likes this.
  3. Spaceace5150
    184
    38
    Oct 1, 2014
    I’m having trouble finding a better wheel for the jack. Any ideas on where to find one?
  4. arge
    arge Active Member
    138
    52
    Feb 27, 2018
    Calgary, Ab
    I would say go for a dolly. I don't know about others, but I found quite difficult to push the trailer over the slightest obstacle and this using a trailer valet. If the driveway is also a bit incline, just a little bit, you don't need too much, it will be very-very difficult. The dolly may be the best help (I used one) and I suggest you to go for the most rated one, ignore they say 600# tongue weight while your trailer may be only 300#, go for the 600# or more. I bent one...
    Spaceace5150 and Sjm9911 like this.
  5. Sjm9911
    7,407
    4,784
    I never did it so im not sure of the best one. The dollys look good , how heavy is the camper?
  6. generok
    generok Well-Known Member
    2,851
    1,181
    Feb 7, 2013
    Anchorage, AK
    Well, TWO plastic wheels might make it a bit easier. There are a LOT of jack assemblies on etrailer.com with dual wheels. I also found this assembly that should allow you to replace your single wheel with two wheels. Dunno if it will help. I always felt the jack wheel was more of a fashion statement than functional equipment.
    https://www.walmart.com/ip/New-6-Du...HRBbmqi_zIKZTD6YcqosGPzGU2cf43XoaAoyWEALw_wcB
    BillyMc and Spaceace5150 like this.
  7. Spaceace5150
    184
    38
    Oct 1, 2014
    I have a very light one.. Rockwood 1640. I am under 2,000 pounds loaded.
  8. Blackripley
    Blackripley Active Member
    217
    161
    Jul 21, 2018
    Goleta Ca
    gardenheather and firepit like this.
  9. Anthony Hitchings
    1,570
    822
    Mar 2, 2019
    take a standard 6" wheel unit (+/-) , remove it, remove the bolt, discard bolt and wheel, buy two 6" wheels with ball bearing hubs, put new 1/2 long bolt (long enough) and 1/2" self locking nut - put bolt thru one wheel, thru the wheel housing, add 2nd wheel outboard, add nut, reinstall - its now MUCH easier to move around than before. The standard wheel is crap - the axle is not even smooth inside the wheel bearing area - one end is all-thread !!
    RGB057 and gardenheather like this.
  10. Anthony Hitchings
    1,570
    822
    Mar 2, 2019
    BTW - if you need to - take a heavy large screwdriver (or similar) in the center of the housing to force the jack wheel to turn where you want it to go as or before you start pushing.
  11. Spaceace5150
    184
    38
    Oct 1, 2014
    thanks for the idea! Where did you find your wheel?
  12. Spaceace5150
    184
    38
    Oct 1, 2014
    Wilkywoods likes this.
  13. Rik Peery
    Rik Peery Well-Known Member
    1,047
    1,150
    Jun 15, 2018
    Virginia
    [LOL][LOL]...how much do you weigh when your not drinking...sorry dude, that cracked me up when I read that [CB]
  14. Steveo4090
    Steveo4090 Well-Known Member
    686
    615
    Jun 26, 2020
    Lancaster PA
    I have that trailer dolly for my 4x8 utility trailer and my john boat trailer, I would never have used it for my pup. But, my pup was 3700 lbs empty so maybe it'd work for yours at 2k. It'd be tough though. Mine is way easier to pull than to push just because of the dolly wanting to turn with that long handle. I wouldn't want to be down slope of my trailer with no way to stop it from rolling if needed. I'd hate to get run over by my own [PUC]
    Kyle R Thorson likes this.
  15. Anthony Hitchings
    1,570
    822
    Mar 2, 2019
    search for this on Amazon
    RWM Casters DUR-0620-08 6" Diameter X 2" Width Durastan Phenolic Wheel with Straight Roller Bearing, 1200 lbs Capacity, 1/2" Axle Diameter
    Spaceace5150 likes this.
  16. Blackripley
    217
    161
    Jul 21, 2018
    Goleta Ca
    We have a generic Mini-Mover for getting our trailer in and out of the garage
    Just because it is tight and hard to maneuver into place.
    Rik Peery likes this.
  17. Camper054
    Camper054 Active Member
    290
    141
    Jul 23, 2019
    Indiana
    I must be missing something here and sorry for that. My driveway is like most and inclined. I use my TV to push the camper in place where I need it to be, whether on a side or inside the garage. Agree, it could be bit of a hassle to hook up the camper with the TV, but it gets the job done for me quite easily.
    Keating and BillyMc like this.
  18. West Coast Canuck
    1,662
    70
    Mar 3, 2005
    I have a Parkit360 L powered trailer mover. Way overkill for your trailer but this was a life changer when I bought it for getting my TT beside my house. My trailer is 8’ wide and the space beside my house is 8’6” wide...I used it to move my neighbour’s Starcraft Centennial in and out of his garage too. Mine is a earlier model than the current Version.
  19. Spaceace5150
    184
    38
    Oct 1, 2014
    Ha! Didn’t catch that!
  20. Steveo4090
    686
    615
    Jun 26, 2020
    Lancaster PA
    I looked at getting one of those a few years ago. I should have done it back then since the prices on them have shot way up. I really don't need it anymore since my htt doesn't fit into my backyard like the pup did.
    Does that mini mover work well for you? I'm assuming you're on pavement only with it.
