Kiddingaround
Goshen winch is so expensive so I bought a cheaper one off ebay (DUTTON-LAINSON DL1402A) it was $40 it has a manual brake not the automatic one that goshen sells. Reason I needed another winch was the automatic brake wouldn't hold, and I seen that as a hazard... so here is the pics
the first 3 taking the square part off
took the square part off the new lever and welded it onto the square tubing
discovered that I didn't have a small enough socket to work ... so I had to cut it off again, and put that piece on and welded it again
so I put everything on and it worked like a dream
