My homemade leveler and storage racks
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by thegoodlife, Apr 29, 2011.
  1. thegoodlife
    thegoodlife New Member
    65
    Apr 18, 2011
    I made a shelf for the inside of the p'up using PVC pipe and closet shelves. We noticed on our first trip that the counter just got cluttered up real bad and that was only an overnight trip. The shelf will give us much more storage.
    I made a leveler too. I used a scissor jack for the lift. Had to mount the jack so that it would pivot at the top and bottom so it would not bind while lifting. I know its probably heavier than a BAL but this one was free. Everything I used to build it was just laying around the shop. A good coat of paint and it will be finished.
  2. gusbell
    gusbell New Member
    302
    Apr 3, 2011
    Very nice on the shelving. I love PVC for this kind of stuff. Almost decided to do that rather than the shelf mod with the spring loaded shower rods. Did you glue the shelf frames and leave the risers ungluded so it can store flat or is it all unglued?
    I'm thinking of making a camp kitchen out of it sometime before our week long trip in August. Couple of shelves and a counter top to set the grill, stove and a wash station on. With enough cross braces under the table top, I think I can do it with fairly thin plywood or something light weight and still have plenty of support. A radial arm saw with stops is your friend with these projects so you can set up a stop and cut everything to the same length. Minimizes the cussing [;)]
    The level looks like it will do the trick also. Hope your a young man because I don't think too many weekends of moving that thing around would agree with my bad back [;)]. Definetly heavy duty and should last you a ling time. And I understand "free". It's one of my favorite words!
    Great job!
  3. thegoodlife
    65
    Apr 18, 2011
    I actually just used some screws to hold the shelf frames together. I forgot to get glue when I went to Lowes and I already had the screws so I used them. You can see the screw heads in the pic. The risers are loose so it stores flat.
    The level is not all that bad. I would guess its probably around 25-30 lbs.
  4. DSCinVegas
    DSCinVegas New Member
    627
    Sep 16, 2010
    WOW... pretty creative TGL... I can't help but be a little frightened though, reminds me of something from the SAW MOVIES..
    lol kidding!
  5. bud121156
    bud121156 Western North Carolina
    4,632
    43
    Apr 15, 2007
    North Carolina
    Nice work, thegoodlife!
    KLM likes this.
  6. redfragglerocker
    redfragglerocker Jen & Mike, Andrew (8) and Justin (5)
    204
    Aug 28, 2007
    Clarence, NY
    WOW! I am truly impressed!
  7. Hacksaw
    Hacksaw Active Member
    1,875
    Aug 23, 2009
  8. colorado_camper
    colorado_camper Member
    852
    Apr 14, 2011
    Denver, Colorado
    Nice! [:D] Never heard of them before but I imagine they'll be receiving some business from me!!
  9. riverwalker
    riverwalker Member
    306
    Jul 25, 2010
    It would be nice if the tire rest pivoted as well, then the weight would be centered on the tire.
  10. Matt O
    Matt O Strangers are friends who have not yet met
    1,358
    Dec 16, 2008
    Chester County PA
    I like the leveler.
  11. thegoodlife
    65
    Apr 18, 2011
    I actually tried to make it that way but did not make the frame wide enough. The tire rest would only pivot a little bit before hitting the frame. Instead of redoing the whole thing, I just cut the pivot assembly off and welded the tire rest to the frame.
  12. riverwalker
    riverwalker Member
    306
    Jul 25, 2010
    I think it rocks , might have to tinker on one for myself:)
  13. dman2
    dman2 Enjoy life!!!!!!!!!!
    37
    Aug 16, 2010
    It looks like the jack is welded in place. I will be making one but not weld the jack in case of a flat on the pup it would come in handy.
