My Homemade Outdoor Galley
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by hsr, Oct 6, 2012.
  1. hsr
    hsr Member
    156
    Aug 31, 2011
    Built this to replace the Cabela's Deluxe Camp kitchen. It was just too big (especially to store inside the PUP), heavy and had no easy way to level.
    Want to give credit to both Xolthrax and dmwoct19 for giving me inspiration in my design. Sort of combined what they did, along with a couple ideas of my own.
    I'm cheap (as in in-expensive), so I started with this 4' x 8' piece of white coated hardboard. It's like a dry erase board:
    Had to cut off about 4" of damaged material, ending up with two table tops that are 22" x 48". Netting me 14.6 square feet of "kitchen" counter top space.
    Then using this aluminum angle:
    Cut the corners like this:
    Made some brackets like these: (the "U" shaped ones came from a piece of square tubing)
    Riveted them together like this:
    Until I ended up with these (the tops are held to the frames with clear silicone and stainless screws countersunk in from the topsides and are held to each other with Liquid Nails).
    Again, being cheap and not wanting to spend $20 each on the legs (sliding door security braces like Joe used) but still wanting adjust-ability to level the tables, found these at Menard's on sale for $3.98 (normally $4.98):
    They have this nifty little point on the bottom to push into the ground to help prevent movement:
    Cut about this much off of each part of them:
    and I have table legs...
    Attached them to the tops with stainless hardware like so (btw, the cleats on the sink end for hanging a trash bag and by the PUP's door for hanging a shoe caddy):
    And - Ta~Da!!! I've got a table. It's attached to the PUP with a standard 2 piece outdoor appliance/table hanger track that I got at General RV for under $5.
    Riveted on a 20" length of 1/16" x 2" aluminum flat as a flange to attach the two tables together (the screws are held to the sink table with nuts all the time). And just use wing nuts for quick attach/detach of the two tables from each other.
    The legs needed an anti folding device. So I bought a 4' piece of 3/16" rod, cut it into four 1' sections, threaded one end for a wing nut and bent both ends like so:
    Painted them silver and attached them to the table frames with push nuts:
    And we have leg braces (run Forest!!! Run!!!)
    Got these cool towel bars at IKEA and added them to the front side of the sink table:
    Cut a hole for the bar sink I found on Craigslist for $5, dropped it in and I have a KITCHEN!
    Sorry, it's just camp driveway at the moment. Going Halloween camping weekend after next and I'll get some pictures of the galley in action. Including the Eccotemp L5 water heater and grey water drain courtesy of Flash82
    Breaking it down:
    Legs folded:
    Where it stows:
    And just how little space it takes compared to that bulky thing I used before...
    So far, I'm pretty happy with how it turned out. Will update that after it's seen some real action and with the full plumbing installed pictures.
  2. fmbhappycamper
    fmbhappycamper PuP Power
    4,325
    Aug 27, 2010
    Love it, patent pending? [8D]
  3. RhinoDave
    RhinoDave Active Member
    2,317
    Oct 29, 2008
    Lake Orion, Mi.
    Very nice job. I love DIY projects.
  4. lbcarr87
    lbcarr87 New Member
    853
    Aug 29, 2009
    Very nice setup and wow that is excellent workmanship.
  5. bondebond
    bondebond New Member
    2,079
    18
    Aug 14, 2008
    I am most impressed. I'm definitely keeping this for some inspiration of my own DIY projects.
  6. Cant Wait
    Cant Wait New Member
    184
    Aug 2, 2011
    Very nice work I need to invest in some more tools, when I have inspiration
  7. mh29803
    mh29803 New Member
    Apr 18, 2012
    WOW!
    Very nice, simple and lightweight.
  8. Shuswap
    Shuswap New Member
    481
    Jan 15, 2012
    Nice work - great story. Enjoyed following yout trek as you acquired the many parts :)
  9. jjkach
    jjkach New Member
    1,782
    Sep 8, 2007
    Great job! Enjoyed your step by step details making your new addition!
  10. mamabean5
    mamabean5 Well-Known Member
    7,254
    40
    Oct 7, 2009
    Very, very nice! Our Cabela wash stand is nice, but I think it's unnecessary to take unless we camp for longer than a weekend. It takes up too much space and too limited in its applications. This is awesome---minimal storage space required and maximum usage options. Definitely think you should consider that 'patent pending' comment [:D]
  11. hsr
    hsr Member
    156
    Aug 31, 2011
    Thank you all for such great, kind comments.
    Mamabean5,
    Don't know why, but when I read your post, was hit with the thought that I should add a third leg and stove/table hanger to the sink table in the event I just want to use that one outside by itself.
    Anyway, thanks again!
  12. mamabean5
    7,254
    40
    Oct 7, 2009
    I think that would be a great addition. I'll be expecting a credit when you market this! [:D]
    (love your Flex---I've got one too)
  13. speckhunter80
    4,782
    64
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    WOW!!! [8D]
  14. BigBaron
    4,585
    Jun 21, 2012
    Thanks for the idea!
  15. Wrenchgear
    3,508
    757
    Aug 5, 2010
    5 Star Eagle Camper
    First off, it looks excellent. Nice job. Thumbs up.
    My only question is.... how well does the white hardboard stand up to water. (spilled out of the sink, off an ice filled beverage cup, rain?) I've used white Masonite in plenty of projects around the house, and whenever water gets on it, it absorbs it, swells, gets fat, the white paint flakes off after it dries, looks like crap in the end. You may wind up having to put a layer of Formica (or some kind of) counter top material over top of the Masonite. You can buy it on a roll in many colors, put it on with contact cement, and its not too heavy.
    See how it goes, great job.
  16. hsr
    hsr Member
    156
    Aug 31, 2011
    Thanks Wrench, couldn't remember the name of the material (Masonite).
    So far, it's repelling water just fine. The dry sides are pointed at each other and the edges all the way around are covered in silicone. I was looking at the sink hole figuring I will need to coat that with something as well.
    Surprisingly, the counter tops of my Cabela's Deluxe Outdoor Camp Kitchen were also made of Masonite. It was about five years old when I sold it and holding up just fine.
    If these turn out to be an issue, I will just remake them with real laminate as you suggested.
  17. brianbigdogsmith
    brianbigdogsmith Camp more Camp more often
    822
    Feb 20, 2012
    Melviindale MI.
    We have a Cabals camp stand and put in our screened in room even on short weedend trips gotta have it under a roof and outside we got rid of our set up inside and do all our cooking and dishes out side.
  18. hsr
    hsr Member
    156
    Aug 31, 2011
    Think I will pick up one of THESE on the way home to put around the sink hole. Silicone should hold it in place and add some extra stiffness to the opening.
  19. shelmily
    shelmily Well-Known Member
    3,487
    415
    Jun 7, 2012
    Northeast Pennsylvania
    Nice Job hsr. I have been thinking of doing something like this for a while. You have given me some inspiration.
  20. Pnyglfr
    Pnyglfr New Member
    58
    Oct 22, 2011
    Very nice.
