My LED experience
Discussion in 'Lighting, Interior and Exterior' started by PDieter, Jun 15, 2013.
  1. PDieter
    PDieter Member
    413
    Aug 16, 2011
    I have a couple older threads but the photo links are all down. I just put up a photobucket just for the pup so now I can pull photos back in. I thought I'd just put up a new thread with the bulk of my experience.
    First I swapped out the ceiling fixtures with really cheap LED's off of amazon. they're kinda blue but I don't care. Then I needed lighting for my outdoor kitchen area and made a 30"strip light for it. I've been very happy with this and found that it even fit perfectly the snap loops on my ceiling for door storage right over the inside stove.
    Some epoxy, aluminum channel, a strip of LED's (led wholesalers on Amazon), wire and an acrylic half round sanded for difusion (tap plastics here in Sea).
    Decided a short strip of 3 might do the step light...works perfect
    if I don't put up the canopy it works on the riser, I tagged the wire into the step light so it's shares the switch.
    Wire connectors make it so I can run at different locations. I have the one on the step light switch and one behind the inside stove
    I've used this set up for a year now with no issues nor regrets. This week while set up in the front yard I had the opportunity to run the lights (all of them) for 7 hours straight without the solar hooked up. After resting the battery it showed no loss of voltage.
  2. ChocoChock01
    4,020
    Mar 7, 2012
    What is your wiring schematic?
    Are you going direct from 12V Bat to LED?
  3. heckufaguy
    heckufaguy New Member
    696
    Jun 2, 2010
    Is the L.E.D. light outside as prone to attracting bugs as a typical white light?
  4. PDieter
    PDieter Member
    413
    Aug 16, 2011
    I suspect it is.
    Yes
  5. Bama Camper1
    Bama Camper1 New Member
    155
    Mar 10, 2011
    I wired the LED strip above the step also and need to mist it with some yellow paint to keep the bugs away.
  6. sonicblaze
    sonicblaze New Member
    74
    Feb 3, 2013
    From what I've read they are not. Bugs are attracted towards a specific range of UV light that is absent in LEDs. The same reason yellow lights are supposed to be better than white lights,because that yellow is supposed to filter out more of the UV range that bugs are attracted to. But...that's just what I've read up on =)
  7. carlr
    carlr New Member
    57
    Jul 9, 2011
    That is true about the UV range. I work in the electrical supply business
    and sell LED lighting of all configurations and styles. I have not tried using it
    yet myself however.
  8. ChocoChock01
    4,020
    Mar 7, 2012
    the advantage of LED's is they emit light is very specific frequencies.
    being that they are not white light filtered to specific colors (such as older traffic lights)
    you will get a TRUE color (Green ~ 550 nm, Yellow [SIZE=78%]~ 520 nm, Red [/SIZE][/size][SIZE=78%]~ 440 nm).[/SIZE]
    This is part of the reason why NEW LED signals look so vibrant (besides pulsing).
    So, you find out which bugs you don't want, look up what frequencies they are
    attracted to and pick which LED's you want to use.
    or get a zapper.
  9. Ductape
    Ductape Well-Known Member
    1,105
    98
    Jun 12, 2013
    Where did all the pictures go?? [?:~{]
  10. imakaratefiend
    imakaratefiend New Member
    Oct 20, 2012
    He turned them off! [:D]
