My over sink/behind sink shelf
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by jonkquil, Aug 10, 2014.
  1. mocamper
    mocamper Active Member
    1,168
    Aug 28, 2013
    Great idea. Nice. Thanks for sharing.
  2. swordfish
    swordfish Well-Known Member
    2,209
    37
    Sep 27, 2010
    More dead space behind the sink reclaimed. I am using 3x L brackets underneath the wood. Dropped in a strip of PVC gap filler.
    This above sink shelving worked out beautifully in our last camping trip.
    upload pics
  3. jonkquil
    jonkquil Active Member
    492
    30
    Jul 20, 2009
    Sweet! Is it permanently attached? Did you use the L shaped brackets you posted from the above post?
  4. swordfish
    2,209
    37
    Sep 27, 2010
    Yes, 3 L brackets by screws. Very steady. PVC gap filler was made from http://www.homedepot.com/p/Stabilit-1-4-in-x-1-3-8-in-x-96-in-White-PVC-FRP-Tile-Divider-Moulding-FRP-DIV-WHITE/202083291 by cutting off the wider side with a blade. So I ended up with a "T" strip.
    The reason for the filler is that the vinyl edging from the stock counter is not very flat. If it was bare wood, I could mate the add-on piece into one piece without a seam.
    Also, I was using the scrap wood I had around for this. It is not too deep to take out too much storage space. But you could make it deeper. Wood strip for the L-brackets was held up by hot glue.
    upload img
  5. jonkquil
    492
    30
    Jul 20, 2009
    Thank you for the detailed instructions and picture. This is my next project!
