Need advice
Discussion in 'First Time & New Camper Owners' started by bigjoey38, Jun 13, 2015.
  1. bigjoey38
    bigjoey38 Member
    40
    Oct 5, 2014
    Well its been about 2 weeks since I got back from Ga, with my new to me camper... so the weather was good today and being a newbie I started to do some hands on training.
    Water flow- Check
    Hot water heater started - check
    Furnace- will do on Sunday.
    Almost there..
    Now while at home I like to keep the battery charged up. I know I can put a charge on the battery but do they sell something else I can use to connect to 30 amp plug?
    I tried connecting an ext cord to an 15 amp/30 amp adaptor and then to the camper cord- it keeps tripping the outlet breaker... any suggestions
  2. nineoaks2004
    7,268
    3,016
    Dukes, Fl
    You are using to many amps, are you trying to run the A/C or microwave, is the HW heater on electric ? 15 amps will not usually carry that load.
    If not then you could have a short in the wiring somewhere.
    I use a battery minder from harbor freight $4.99 on sale 9>99 normally, this keeps the battery topped off when setting.
  3. SmilinBeard
    SmilinBeard Member
    507
    Feb 18, 2008
    how long of an extension and what gage wire. If it is long and light gage, you will build up significant resistance. I run a 100 ft cord successfully, but it is 12 ga.
  4. bigjoey38
    bigjoey38 Member
    40
    Oct 5, 2014
    I have everything off...
  5. Bratman
    Bratman Give me a clear sky and a drum.
    25
    Oct 26, 2014
    I have mine set up in my drive way next to the garage with the 30/15 adaptor in the normal a/c that has a 30 amp breaker I've even run the air for short amounts of time to test it etc... 2013 Starcraft 816 with no problems... I'd have my wiring checked by a pro, that's something I wouldn't want to deal with at the CS!
  6. capy235co
    capy235co Member
    719
    Jan 9, 2011
    Seal Beach, CA
    My first thought is to try to get close enough to the nearest electrical outlet and try eliminating the extension cord. I would think your Trailmanor should be able to reach.
  7. Customer
    Customer Well-Known Member
    2,436
    243
    Jun 5, 2014
    Tripping an overload breaker or a GFCI?
  8. sleach
    683
    147
    May 17, 2014
    Boulder, Colorado
    BigJoey, glad to hear you got your new Trail Manor home safely. You had a long ride through some rough weather areas.
    When selecting a battery maintainer, the more you pay the more you get. Be sure to choose a sophisticated model with a desulphating feature. We have been very pleased with the results from a CTek 3300. Even then, check electrolyte level from time to time.
  9. bigjoey38
    bigjoey38 Member
    40
    Oct 5, 2014
    GFCI
  10. Customer
    2,436
    243
    Jun 5, 2014
    Thanks, that makes a big difference in the answer.
    You have a ground fault. The first likelihood is your extension cord. Get rid of it and use a quality cord. If that doesn't work, let us know, it could be a fault inside the trailer.
    This is potentially a very dangerous situation, it needs fixed.
  11. bigjoey38
    bigjoey38 Member
    40
    Oct 5, 2014
    Thanks- I will switch out extension cord and try it... They had the camper plug in via 30 amp plug and had no issues at the dealer before I pulled it of the lot.
  12. Keith Hawkins
    Keith Hawkins Active Member
    1,336
    Mar 8, 2015
    Most household circuits are not for one receptacle only. I would actually trace the circuit on the house side, you may find that the microwave, fridge, Television, ect are on the same circuit you are hooking up to causing the breaker to flip.
  13. bigjoey38
    bigjoey38 Member
    40
    Oct 5, 2014
    Thanks
