Need help picking a new generator
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Vilinsky88, Sep 7, 2020.
  1. Blackripley
    Blackripley Active Member
    218
    162
    Jul 21, 2018
    Goleta Ca
    Vilinsky88,
    It is possible all you need is to modify the AC unit with a soft-start device, so it can work off the generator you have now.
    A soft-start is a device that takes the hard/fast AMP draw strain off the generator. When the AC's compressor kicks in there is a hard spike in the amp draw that a smaller generator can not react quickly enough to. Bigger generators or when plugged into shore power there are more AMPs in reserve, on a smaller generator might have the AMP rating for it but has to run up to meet the demand of the higher draw.
    take a look that these sites for a more in-depth explanation
    https://networkrvstore.com/products/softstartrv
    https://www.trailerlife.com/tech/this-is-cool/
  2. JimmyM
    JimmyM Well-Known Member Gold Supporting Member
    3,070
    1,056
    Jun 5, 2014
    Franklin, MA
    A 3500 will work for you if you're not reckless. If you're running the microwave (1000W/8.3A) and a toaster (1100W/9.2A), then the AC kicks on, It'll probably trip.
    A champion 3500 delivers 3200W continuous (26.7A). The Predator delivers 3000W continuous (25A).
    I have a 13,500btu AC unit with a MicroAir EasyStart installed. I can start and run it on a 15A circuit. Just barely if it's the only thing.
    Blackripley likes this.
  3. CajunMan
    CajunMan Active Member
    101
    71
    Mar 7, 2020
  4. nhlakes
    nhlakes Well-Known Member
    704
    373
    Oct 15, 2011
    DE and NH
    My Honda EU2000i was not enough, so I bought a Champion 3500 dual fuel. It was too loud for us so I returned it and bought a Honda EU2200i to run in parallel. The 2 Honda's are much easier to move around than a 3500 unit. I hear good things about the Predator 3500.
  5. NMroamer
    NMroamer Well-Known Member
    853
    588
    Apr 21, 2016
    Albuquerque NM
    A little bit of research would have made this thread unnecessary.
    Anthony Hitchings likes this.
  6. HappyCamperCanada
    HappyCamperCanada Member
    81
    66
    Aug 11, 2019
    Nova Scotia, Canada
  7. ABJohnson
    ABJohnson New Member
    Apr 6, 2020
    Mississippi
    Check out the Predator 3500 sold at Harbor Freight stores for $799. On Consumer Reports it ranks right up there with Honda but at a fraction of the price. I purchased one this year and have been impressed with it.
  8. JimmyM
    3,070
    1,056
    Jun 5, 2014
    Franklin, MA
    I haven't needed a generator yet. But when I get one. This is the one I'm getting.
    One thing to note, there's a price to be paid for that low price. You need to carefully break in the generator before putting a full load on it.
  9. Kelli McDowell
    Kelli McDowell New Member
    Aug 9, 2018
    Yes but it help us who are researching . . . . :)
    Spridle likes this.
  10. grandpa mikey
    grandpa mikey Member
    37
    36
    Aug 7, 2020
    Portland, Tx
    well said imho
  11. dave123
    dave123 freedom is not just another word
    191
    Mar 29, 2013
    is everyone saying that a 2200 watt honda generator won't operate a 5000 btu ac???? i'm very new to ac generator stuff and have a small aliner and moving to florida help please thank you
  12. giadiep
    giadiep Active Member
    476
    236
    Sep 5, 2015
    Syracuse, NY
    I think they are referring to the 13.5k or 15k btu roof mounted air conditioners.
  13. dave123
    191
    Mar 29, 2013
    asking people and the boards is doing research
  14. Bosgarage57
    Bosgarage57 New Member
    24
    Mar 11, 2020
    After getting a new to us popup, I have been watching the Predator 3500 inverter generator. Going to wait until it goes back on sell for sub $700 and grab one.
  15. NMroamer
    853
    588
    Apr 21, 2016
    Albuquerque NM
    Amateur opinions are not qualified technical answers.
    IDezine likes this.
  16. Anthony Hitchings
    2,205
    1,213
    Mar 2, 2019
    Oakland, California
    BUT - they have to start somewhere - which should have been reading the prior threads here and elsewhere on this tired old subject.
  17. rhbowler
    rhbowler New Member
    Mar 25, 2020
    Costa Mesa, California
    It says you are a well known member, so are you well known for being rude to new people who ask a question YOU don't think they should have?? No one is forcing you to read this thread, skip it and move on if it bothers you so damn much
    eoleson1 and JimmyM like this.
  18. NMroamer
    853
    588
    Apr 21, 2016
    Albuquerque NM
    You got it all wrong. Nobody has a thousand dollars to spend on something that is unusable.
    if he would have gotten the info from the AC data plate me or someone else could have helped get the right generator.
    voltage,amps and maybe wattage is the info needed to make the right buying decision.
    Not opinions.
  19. Blackripley
    218
    162
    Jul 21, 2018
    Goleta Ca
    In my area, the Honda 2200i is available to rent at most of the tool rental houses and at a lot of Honda motorcycle dealerships. You could rent one for a weekend or for a day to test, or you might even be able to borrow one from a dealer to test, even if it's in their parking lot.
    We have a Ryobi 2,300-Watt Super Quiet and we are able to run the Cool-Cat AC in our Rockwood A-frame.
  20. BillyMc
    BillyMc Well-Known Member
    2,008
    1,348
    Mar 25, 2018
    Our AC, like most PUPs is 13,500 BTU. It pulls 17 amps on startup and nearly 15 amps running. The 2200 maxes about 18 amps. While by the numbers it will run my AC it doesn't have any power to run other stuff.
    Spridle likes this.
