need input on repair
Discussion in 'Camper Restoration Projects' started by Debra Reed, May 29, 2019.
  1. Debra Reed
    Debra Reed New Member
    May 29, 2019
    the area above my door on my 1995 starcraft spaceflyer feels soft like the wood is rotted or something. any ideas, forums or youtube videos of how to repair this area ? I am new to pop up campers and hope I did not get ripped off buying this one.
  2. Shaman1
    Shaman1 Well-Known Member
    2,236
    514
    May 13, 2011
    Oklahoma City, Oklahoma
    Are you talking about the side board or the ceiling? How far out is it soft? How handy are you with wood work?
  3. Debra Reed
    May 29, 2019
    the piece on the side right above where the door is, probably need about a 3 ft piece.
  4. Shaman1
    2,236
    514
    May 13, 2011
    If you are comfortable doing wood work, it's doable. It will be a lot of work though.
  5. Debra Reed
    May 29, 2019
    Any ideas on any instructions or you tube videos
  6. Shaman1
    2,236
    514
    May 13, 2011
    I don't know of any you tube (they may exist). Most deal with complete roof repairs. What part of the world do you live in?
    If you're going to do this, you will want to remove the paper covering that sidewall first. Then you can be sure how far the damage goes.
    A Dremel will make the job easier and do the least damage. I would cut back a couple of inches from where it seems solid.
  7. Shaman1
    2,236
    514
    May 13, 2011
  8. Debra Reed
    May 29, 2019
    Thanks I am in Austin Texas not looking forward to the repair but I gotta try to save it
  9. Debra Reed
    May 29, 2019
  10. Debra Reed
    May 29, 2019
    I guess I am unclear by what you mean "remove paper cover" this seem like the piece is like aluminum on the outside and perhaps inside where the drop down door attaches to the wall. seems like there is wood or pressed wood inside of it.
  11. Logjammer
    Logjammer Member
    34
    23
    Jan 17, 2019
    I think what Shaman1 is referring to is the inner covering on the panel of the roof sideboard. You mentioned replacing a small section of the panel above your door
    which would be rather difficult because that panel is a structural 'beam 'that supports the roof from corner to corner and should be replaced in one piece for strength.
    Here is a thread where I had to do that on my flagstaff. I replaced the rotted OSB board with a solid cedar board....
    http://www.popupportal.com/threads/roof-repair-on-2003-flagstaff.122509/
  12. KJMcNeil
    KJMcNeil Member
    80
    21
    Aug 22, 2018
    Salt Lake City, UT
