Need special smoke, CO2 detector for RV?
Discussion in 'Campsite Electronics' started by JungleJim, Jul 9, 2011.
  1. JungleJim
    JungleJim New Member
    990
    Feb 25, 2008
    I'd like to get a smoke detector and CO2 detector for our camper.
    I've seen ones made for RV's. Do I need to pay the extra money for RV specific detectors? Or can I just put in any detector? Is there a difference? (Are the RV ones supposedly more durable?)
  2. cruising usa
    cruising usa New Member
    508
    Aug 19, 2006
    The combination Carbon Monoxide (CO) and LP detectors are probably the best way to go for an RV of any sort.. They need to mounted low as Propane is heavier than air. A smoke detector should be mounted as high as you can get it. I would put a Smoke Detector in a hard side if I had one.
    I do not know about the durability issues.
    Happy Camping
    Ken
  3. JungleJim
    990
    Feb 25, 2008
    All of those are 12V hard wired. I need battery operated.
    (Science teacher here...am familiar with the densities of the gases [8D])
  4. cesperon
    cesperon New Member
    151
    Jul 3, 2011
    I asked about CO2 detector and was told that we didn't have to worry about it because the pup was so airy. Was I given misinformation?
  5. cruising usa
    508
    Aug 19, 2006
    Your right CO (Carbon Monoxide) should not be as much a problem in a pup, however I always leave my door window open about 2" when operating my furnace. Usually have a window open when using the stove.
    Happy Camping
    Ken
  6. bheff
    bheff Well-Known Member
    1,504
    915
    Feb 24, 2011
    NW Arkansas
    I would say this is bad advice! Get the detector and you will get to enjoy camping next year as well. We have a propane leak detector, CO2 detector and smoke detector. Why risk it?
  7. mdigby
    mdigby New Member
    279
    Sep 9, 2007
    I agree with the comments that LP, CO and smoke detectors are good to have.
    BUT I think the original question remains unanswerered...
    Does one need to buy the RV specific dectetors or are the home type adequate?
    Thanks, I'd like to know also.
  8. ErikRuud
    ErikRuud New Member
    473
    Aug 10, 2009
    St. Charles, IL
    A home model Smoke an CO detector should be fine.
    However most RV models also detect LP gas leaks.
    Also note the CO2 is Carbon Dioxide, so unless you worried about people opening your soda, you won't need a detector for that. [:D]
  9. mdigby
    mdigby New Member
    279
    Sep 9, 2007
    Thanks for the info. It's on my list of things to get done!
