New AC gasket leaked during storm this weekend, need advice on securing it.
Discussion in 'Heating / Cooling Systems' started by Fasttimes7, Aug 24, 2015.
  1. Fasttimes7
    Fasttimes7 Member
    116
    Sep 7, 2014
    Over the weekend we did a trip to central FLA and got poured on. I started to see water dripping from the AC unit and knew I had a problem. I took down the face started to see that the AC unit was not near snug enough. The 4 outside bolts were very loose. Not knowing what to do I ended up tightening the 4 bolts all the way that I could and we had no more leaks. But now that I'm searching around for what the correct amount of torque is I see people suggesting to only tighten it down to around 60% of the gasket pancaking out. Is this the case? I feel because I didn't tighten it down to begin with is why it backed out from traveling. What is the correct procedure and torquing of the unit to the top?
    Also, there are 4 screws that have springs on them that I'm assuming are to help with jars and bumps in the road? Two of mine are basically stripped to the point that I can't tighten them in. Does anyone know if you can order more of theses screws from Dometic or somewhere else?
  2. PinnMcrack
    PinnMcrack Active Member
    1,274
    Aug 23, 2011
    I have tightened mine down until I can't tighten anymore. If you had a Coleman Mach AC unit I have replacement bolts... darnit
  3. Fasttimes7
    Fasttimes7 Member
    116
    Sep 7, 2014
    After reading this http://bryantrv.com/roofacleaks.html I tried to re-tighten the bolts and leave a gap of 1/4 to 1/2 inch. Problem is that with a gap close to that level the 4 bolts are pretty loose. For sure they would back loose from vibrations on the road. I ended up tightening them as much as it took to be at least snug.
  4. bondebond
    bondebond New Member
    2,079
    19
    Aug 14, 2008
    Sounds like a problem with the gasket. I hate to say it but I would replace it again. I just roll my A/C on its side, remove the old gasket, put the new one with the adhesive side stuck to the underside of the A/C and roll it back over the hole. I tightened about half way down and no issues. That's been four years ago. It's probably time to tighten them up a smidge as the gasket will compress and eventually fail over time.
  5. Customer
    Customer Well-Known Member
    2,435
    248
    Jun 5, 2014
    Sounds to me like you need a new gasket. Only tighten the four bolts enough for the seal to compress and seal all the way around.
  6. Fasttimes7
    Fasttimes7 Member
    116
    Sep 7, 2014
    Problem is when I do this the bolts are still hand loose. They'll just work themselves more loose and the ac will then allow water in. Not sure if I should try some Lock-tite?
  7. Customer
    2,435
    248
    Jun 5, 2014
    New gasket
    tighten bolts till gasket is partially compressed and bulging
    the compression of the gasket holds tension against the bolts.
    DO NOT use Loc-tite.
