New Adventure with Starcraft 1999 Venture Pop-Up
Discussion in 'First Time & New Camper Owners' started by Malonie Moeller, Jun 28, 2020.
  1. Malonie Moeller
    Malonie Moeller New Member
    Jun 18, 2020
    6732BA4D-1318-4F56-9123-B98D0DC25233.jpeg AC1ECDA4-00F0-4488-9E76-1FCD9B153915.jpeg
    left side
    Right side
    Right side
    We recently purchased a 1999 Venture and we are getting it set up in the drive way to do a deep clean and make sure it’s functional before camping. All has been good until the door set up. When attempted to latch the top and bottom door together, I noticed the latch is way off and won’t even grab the hook. Then I noticed the gaps are uneven on either side of the frame. It was definitely level prior to, and we’ve even done some adjusting either way with no change. Any suggestions?
  2. Raycfe
    16,975
    2,529
    First thing .......
    Now I have a question for you. Did you level your camper side to side with something under the tire on the low side or do something else.
    Did you level your front to back using the tongue jack or something else.
    My point being .... many times the stabilizer jacks are used to level the camper, and they are not for that. They can distort the side panels of the camper and change the door opening. They are only to take the wiggle out and to prevent a seesaw effect when walking to the rear of the camper.
    When the camper a leveled correctly, it maybe now ...with no body tension do some measuring. Is the door opening equal up and down side to side. when that is OK and the roof isn't too high the door should fit. Our Jayco didn't even have catches to hold the top to the bottom, none needed. I wonder if those were added poorly.
  3. WrkrBee
    WrkrBee Well-Known Member
    3,551
    1,510
    Welcome to the Portal from South Carolina. Details are good, but a full picture of the door may add more to the story.
  4. Malonie Moeller
    Jun 18, 2020
    Thanks for the replies! We did level using the stabilizers initially, won’t make that mistake again. Seems like something is still going to be up with the door, since we’ve checked the level all over, but we’ll do better next time and see if it fixes it. How do we level it from side to side? It’s parked in the driveway. But I’m assuming maybe we would need to do that at a campsite potentially. Here’s a picture of the full door. BE2329FB-5FAD-4E04-8F5F-91DF367409B2.jpeg
  5. kcsa75
    kcsa75 Well-Known Member
    3,641
    1,843
    Sep 9, 2013
    Kansas City
    First, Welcome to the forum.
    From your photo, it doesn't look like the Pup is level from front to back. Using the tongue jack, lower the front end and see if that helps.
    To level side to side, you need to put something under the whichever wheel is low. I use 2x8 lumber, but a lot of folks buy "lego" blocks like these to put under the wheels.
    https://www.amazon.com/Camco-Leveling-Hydraulic-Frustration-Free-Packaging/dp/B072VSBLH7
  6. JoeW22
    JoeW22 New Member
    Jun 23, 2020
    Wisconsin
    I use a BAL leveler ..you can get them on Amazon..so much easier than backing up or pulling forward onto blocks
    Check out the video
