New battery and still no power
Discussion in 'Wiring' started by BDeF, Jul 2, 2020.
  1. BDeF
    BDeF New Member
    Jul 2, 2020
    We bought a 2012 Forest River on Mother’s Day and I haven’t been able to get the 12v power to work. Everything is functional on shore power.
    The old battery wasn’t holding a charge so I got a new one but still no juice is flowing. Kill switch is off. Red wire connected to + and white connected to -. Master switch in correct position. I’m no electrician but am hoping to get some other ideas before I take it somewhere for assistance.
    Also attaching a couple of photos to see if anything looks off.
    Thanks everyone
  2. jmkay1
    5,657
    2,464
    Have you checked the fuses in the camper yet.
  3. WrkrBee
    WrkrBee Well-Known Member
    3,875
    1,686
    I see no pictures. What are you calling the master switch- a battery cut off? Got a multi-meter?
  4. Raycfe
    17,005
    2,576
    Trace the red cable to see where it goes. There has to be a cable that goes the convertor (could be the red one or it's missing).
  5. Chrismtl
    Chrismtl Active Member
    146
    29
    Jun 14, 2014
    Pincourt - Quebec - Canada
    Following as I have the same issue in my 96 Viking. Switched the converter to 12v with a new charged battery and nothing. Never used the 12v in the 3yrs I've owned it, but we are planning to Boondock in September. Glad I checked it now.
  6. rabird
    7,262
    537
    N. TX
    BDeF, your master switch is actually the back of the refrigerator, turn all that OFF.
    You are missing the battery fuse in your World Freindship power center.
    I'd use a 30A but many folks have 20A there. The sticker suggests circuit #4 to use a 25A fuse
    ya might change fuse #1 to 10A as indicated on sticker
    Your WFCO 8725 https://photos.app.goo.gl/YsK2QmY8e7ZiVi928
    Back of your fridge https://photos.app.goo.gl/57W57ixbGYx5Ht87A
    please add a signature with your popups info so all can see on each post
    https://www.popupportal.com/account/signature
  7. rabird
    7,262
    537
    N. TX
  8. TheLight75
    TheLight75 New Member
    23
    Sep 8, 2019
    Eastern Massachusetts
    I would suspect the battery wires may be broken somewhere along the length of the frame.
    Two tests you can try with a cheap multitester:
    Pre: Disconnect both wires from battery. Make sure you’re also not connected to shore power.
    Use the multitester in continuity test mode (if you touch the two probes, it will beep as long as they stay together).
    1. Ground check, short check
    - Touch one probe to the negative battery wire and touch the other probe to bare metal on the frame. It should beep indicating the battery negative terminal is properly grounded.
    - Touch one probe to the battery positive wire and touch the other to the battery negative wire. It should NOT beep. If it does, you have a short between ground and your positive battery terminal.
    2. Positive check
    - Tape the battery positive and negative terminals together. Go behind the converter and identify the red wire that comes from the battery. Touch one probe to the red wire and the other probe to a ground wire (or bare metal on the frame). It should beep since the battery terminals are shorted together.
    - Separate the battery positive and battery negative terminals. Run the same probe test again. This time is should NOT beep. (If it fails, you have a short on the battery positive wire from the converter end)
    If all these tests are successful, your wiring is fine.
  9. Raycfe
    17,005
    2,576
    Master switch at back of refrigerator ........ I don't think so .....sorry ..... those switches are for the refrigerator. The green switch is for 120 VAC heating element and the red is for the 12 VDC heating elements ...... for the refrigerator.
  10. Anthony Hitchings
    1,257
    584
    Mar 2, 2019
    battery wires not likely to break, tho they may be disconnected.
  11. WrkrBee
    3,875
    1,686
    They will be destroyed by battery acid and salt. If inside a terminal, you may not see it. Circuit is still broke.
  12. rabird
    7,262
    537
    N. TX
    thank you ray for your concern, the OP called them master switch and I noted thy were not, not sure your issue. you should direct your reply to him and not me providing education.
    did ya notice the missing fuse?
    other pic shows missing battery fuse, did I get that nomenclature correct!!! rflol
  13. BDeF
    BDeF New Member
    Jul 2, 2020
    Thanks. I'll get a new fuse and report back.
  14. Raycfe
    17,005
    2,576
    I didn't see the photos ........ and I really don't care who called what. But if someone trying to solve a problem they should have the correct info.
  15. rabird
    7,262
    537
    N. TX
    That is what I provided and the OP is taking action to replace the missing fuse! I regret your confusion but I did provide link to the pics and just for you I will post it here, this what the OP suggested was 'master switch', no its the back of the fridge. "Turn it all off".
    I also provided a link to the op's WFCO 8725 but here is it for all!
    Now you can reconsider your 1 st post (or not)
  16. Raycfe
    17,005
    2,576
    rabid ............. chill ......... If you don't like my god-damm answers ----don't read them. NO ONE is ragging on you. I was just stating a fact.
  17. rabird
    7,262
    537
    N. TX
    sorry ray, if your 1st post was sufficient I wouldn't of posted!
  18. BDeF
    BDeF New Member
    Jul 2, 2020
    The missing fuse did the trick, so thanks for the simple suggestion.
    Another problem now... Had lights/furnace for one night but somehow the battery drained with very little usage. I plugged it in to an outlet over 24 hours ago and it's still sitting at 11.50 volts. Am I missing something else that is easy? Or do I have a bad battery?
  19. rabird
    7,262
    537
    N. TX
