New flooring doesn't match up
Discussion in 'Camper Restoration Projects' started by Spankynuts, Jun 27, 2017.
  1. Spankynuts
    Spankynuts New Member
    Jun 3, 2017
    hi I'm redoing the floor and Rona didnt have marine grade plywood but went with the Acx. Which is the next best thing . Question is once the floor is in the plywood seems to be one layer high then the existing osb ....any solutions or anyone ran into this issue ?
  2. IngieBee
    IngieBee New Member
    25
    Oct 2, 2016
    Sounds like the plywood you got was slightly thicker. Your choices are a bit limited. Redo the other side with same product, find the right thickness plywood and do over again, find something of the right thickness to overlay the old side with??? Maybe some solid vinyl squares, the type they use in hospitals or schools is pretty solid and might be the right thickness? Then finish off with your flooring??
